ECU and PROMS
Old Feb 15, 2024 | 09:17 AM
MattMostLikely's Avatar
Car: 1986 Pontiac Firebird
Transmission: Automatic
ECU and PROMS
I’m in the process with a project 1986 T/A TPI, I pulled my ECU out and found it was a reman. 1227165. When I look up an ECU on rockauto they list a 1226870. What is the correct part number for this year? Also at work I found out we offer a plug and play JET 18617. Will the jet work in my current ECU? Will I still need to flash my old ECU? Please help.
Old Feb 15, 2024 | 09:39 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: ECU and PROMS
Aum or amu chip code right now ?
numbers for refurbished 165 ecms are 77-7165, 16198259 and 88999194.There’s a few more too. The 1226870 will not work it’s a 85 one year only and uses a prom
and calpak different wiring pinout as well.
Old Feb 15, 2024 | 10:00 AM
Re: ECU and PROMS
I do not have the chip code atm will have to get it after I get off work
Old Feb 15, 2024 | 12:56 PM
Engine: Lb9
Transmission: M20
Re: ECU and PROMS
Aum has slight issues depending on date made.
Old Feb 15, 2024 | 05:27 PM
Re: ECU and PROMS
Forgive me, but I’m not to sure what a amu or aum is, I did however grab some photos once I got home
Old Feb 15, 2024 | 06:59 PM
Engine: Lb9
Transmission: M20
Re: ECU and PROMS
Awc has some service bulletins 86-194 not sure what the issue was
its a nb2 and na5 emissions chip that’s fed and ca requirements. I wouldn’t spend the money on a jets. What issues are you having?
Old Feb 15, 2024 | 07:36 PM
Re: ECU and PROMS
So the car is in a no start condition since I’ve got it, I’ve went through changing multiple parts. I’m at a point where I believe the ECU is the issue. Was not sure if the one in my car was correct or not. And if I could just purchase a preflashed chip or would I need to get a whole ECU and put my old chip in it. I don’t really have a history working with
Old Feb 15, 2024 | 07:39 PM
Engine: Lb9
Transmission: M20
Re: ECU and PROMS
fuel pressure ?
spark ?
injector pulse when checking with a noid light ?
any stored ecm codes ?
do you have a scanner to see if the ecm is getting a reference pulse ?
Old Feb 15, 2024 | 07:46 PM
Re: ECU and PROMS
I do have spark, pulse to the injectors, and fuel pressure is good. I dont believe I have any codes, I’ll have to double check with the scanner.
Old Feb 15, 2024 | 07:49 PM
Engine: Lb9
Transmission: M20
Re: ECU and PROMS
While cranking with the est disconnected is the timing close to 6dbtdc ? . If you have injector pulse, good fuel pressure and spark. Timings off or you need to do a compression test.
Ownage1100
Feb 23, 2010 09:22 AM
AM91Camaro_RS
Jan 16, 2004 12:47 PM
danielocr
Mar 5, 2003 11:24 AM
Mangus
Feb 14, 2003 08:37 AM
