FiTech swap
Old Feb 23, 2024 | 06:05 PM
Mikah1988's Avatar
FiTech swap
Hey guys I tried searching the forums but honestly nothing was showing up for my questions.
I am rebuilding my L98 and will be running Fitech EFI. I'm wondering if anyone has any info on what fittings I need to use my existing fuel lines? I'm upgrading the pump, it's a Arizona car with no rust so I don't see the point in replacing lines! Any help is appreciated 👍🏻
Old Feb 23, 2024 | 06:39 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Re: FiTech swap
I'm going to be using these for my Holley terminator system -
EAR-AT9894DBJERL on the feed line M16 x 1.5 to -6AN
EAR-9894DBHERL on the return line M14 x 1.5 to -6AN
This gets rid of the factory rubber section and attaches directly to the hard lines. I didn't trust the 35 year old rubber OEM fittings.
Old Feb 23, 2024 | 06:48 PM
Mikah1988's Avatar
Re: FiTech swap
That's not a bad idea. Didn't think about the rubber lines. Probably because they look in good shape. But better safe than sorry. Thank you!
Old Mar 5, 2024 | 11:22 AM
wruiz's Avatar
Car: 1990 Iroc z-28
Engine: 350 TPI STOCK
Re: FiTech swap
On the same…kinda…subject, do I have to replace stock injectors and fuel pump when installing FiTech? I’m replacing a stock 350sbc with a crate 350 with upgraded cam, heads, etc. I wonder if upgraded pump/injectors are needed. Or a fuel regulator would suffice? Thanks for your feedback.
Old Mar 5, 2024 | 11:34 AM
Andreas_91GTA's Avatar
Car: Trans Am GTA 1991
Engine: L98 with Super Ram and Fitech
Axle/Gears: 3.23:1
Re: FiTech swap
Are you keeping the tpi-setup (including pump and fuelrails with stock regulator) to bolt on your crate? If so, then you're all good. If you decide to put bigger injectors you just put in the new value in the fitech. Stock tpi 350 injectors are 22 lbs.
Old Mar 5, 2024 | 01:46 PM
wruiz's Avatar
Car: 1990 Iroc z-28
Re: FiTech swap
Thanks for the response.
no, I have a HSR intake with aftermarket fuel regulator. not sure whether stock pump or injectors would work.
Old Mar 5, 2024 | 02:11 PM
Axle/Gears: 3.23:1
Re: FiTech swap
That should not be an issue, as long as you know the size of you injectors and run stock fuel pressure. I run Accel super ram, stock injectors and pump.
cerhart
Dec 12, 2011 11:48 PM
capsfan101
Dec 31, 2010 03:21 PM
86irocu
Oct 31, 2007 10:40 PM
Nasty_Bird_'90
Aug 21, 2002 10:16 AM
Bowtie Racing
Jun 1, 2001 12:53 AM
