5.7 TPI Stumble Only in Drive
Old Apr 30, 2024 | 01:38 PM
ramblingarage's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7 TPI
Hi all -
I have a stumble in my 5.7 TPI, it only occurs when it's in Drive it seems.
The car has a freshly cleaned MAF, clean air filter, new plugs and wires, new valve seals and relatively new injectors.
I'm thinking possibly IAC? Maybe TPS?
I can pull the IAC out, if I don't adjust it while out, I can insert without relearning, right? I'm wondering if it's just dirty.
My thoughts are a vacuum leak would probably happen all the time, not just in drive.
Thoughts are appreciated. Thanks!
Old May 3, 2024 | 08:24 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: 5.7 TPI Stumble Only in Drive
I had similar issues... I changed the fpr and that helped although it did not get rid of the problem completely.
Old May 4, 2024 | 02:33 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Its rarely the iac, not saying its not it but its rare
Old May 4, 2024 | 02:49 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Have you done a tps sweep to check for an open in the tps signal from tps ?
Old May 4, 2024 | 04:27 PM
ughmas's Avatar
Car: '90 Formula '88 GTA
Engine: 305 TPI 350 TPI
Transmission: T5 700R4
Axle/Gears: 3.42 10 Bolt 3.27 9 bolt
Check fuel pressure, if the pump is going bad it can bog hard under load (when in gear for example)
Deadworm
Oct 10, 2016 03:22 PM
55mikey55
Aug 26, 2010 06:55 AM
camaro87-alex
May 18, 2009 03:50 AM
Daniel U
Northern California
Aug 6, 2007 01:34 AM
rallysport
Dec 3, 2001 05:37 PM
