Please help with my code 43
Car: 1992 camaro z28
Engine: Factory 5.7
1992 camaro 5.7. I’ve look all over the forums and internet. Did everything and still have the dreaded code 43, I don’t know if that directly connect to my car running rich but I’ve read that it can be the cause. I even ran a direct line from the ecm to the knock sensor. Still no luck.
what I replaced so far.
- knock sensor
- distributor
- ignition coil
- ignition control module
- Spark plugs
- spark plug wires
- MAP sensor
- coolant temperature sensor
- Idle air control valve
- Throttle position sensor
- Fuel filter.
I threw everything I can think of involving ignition and spark. Can some please shed some light and answer my prays. Thank you.
Car: '86MCSS
Engine: 396 .030"
Transmission: M20
Re: Please help with my code 43
From my experience it pulls timing off idle and more in the higher rpms. Code 43 is usually associated with a KS circuit. Knock sensors from '85 through '92 can physically look alike but the resistance can be different depending on the application. Take a ohms reading center of the sensor to the body of the sensor and it should be ~3.9 ohms. If it's 100k ohms, chances are you have the wrong KS. Been told KS are torque sensitive and over torquing them can damage them or make them oversensitive.
Post #2
Post #2
Engine: Factory 5.7
Oh ok. I never thought about that. I ordered me an oem KS and it’ll arrive tomorrow. I’ll check the readings on my new one before installing. The one I have on right now was a cheap generic brand off Amazon. Hopefully this was the cause all along. I’ll update have an update after my findings. Thanks.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Besides the ks being 3.9k ohm make sure head temp switch and ks arnt swapped electrical connections.
Engine: Factory 5.7
Yeah. When I first got the car someone cut the wires to the KS and temp sensor, the wires were blue and white. I did some research and people said the blue wire was for the KS and the white one was for the TS. And I believe the KS plug had a blue wire on it. I replaced the old plug for it because I crushed the housing while trying to remove it. The aftermarket plug came with a white wire though. But I think I’m in the clear. Thanks 🙏🏽
Engine: Factory 5.7
UPDATE!
so today the oem KS came in. ACDelco part number 213-92. I ordered it from Amazon for about $55. Amazon says it doesn’t fit but it does, I checked by going online to GM parts store, AutoZone, and Orilleys. So took off the cheap off brand KS and switched it with the OEM part. I reset the codes by disconnecting the negative battery terminal. Waited a few mins and started the car up. NO CODES!! Now I have to connect the KS back to the factory wires because I ran a straight wire from the KS to the ecm.
so for whoever is reading this. Please please please, always get OEM parts.
CD MaroMan 91
Apr 17, 2002 02:46 AM
