TPI 42 and 43 codes error
Old Jun 30, 2018 | 04:31 PM
Camaro29's Avatar
Car: Camaro IROC 86
Transmission: 4L60
Hello friends
I have trouble with engine.
At first i want to say, that i have L98 from vette 1987 rebuild to MAP and ECM 1991 Camaro.
Check engine light say, that we have 42 and 43 errors.
I think the reason is that i have distributor from vette and ECM from camaro.
Can it be the reason of trouble...
Buy the way, at 2000 turnaround i see Exhaust Manifold that was WHITE color, not red, not black - WHITE!!!!! Plastic parts was melt under the hood in few seconds
Old Jun 30, 2018 | 05:35 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPI 42 and 43 codes error
Hei devorced could and coil in cap will swap no problem. As long as the 4 icm wires are hooked up correctly. Have you gone through the trouble tree for 42 & 43 ?
http://www.chevythunder.com/est_code_42.htm
Check the ks ohms from the center pin to housing or ground. If it’s from tpi maf it will be 100 ohms tpi ss 3.9k .
Sounds like your super lean and need to check fuel pressure or possibly replace your injectors. Does the engine have a lean miss?
Old Jun 30, 2018 | 05:40 PM
Camaro29's Avatar
Car: Camaro IROC 86
Transmission: 4L60
Thank youfor link!
What does it mean "As long as the 4 icm wires are hooked up correctly" ?
Old Jun 30, 2018 | 05:50 PM
Engine: Lb9
Transmission: M20
There are four cavity’s on the ignition control module. They need to be hooked up as followed see the icm pin letters. They are the same for y and f body’s. Just a large 4 way connector for large cap small for small cap.
Old Jun 30, 2018 | 06:17 PM
Engine: Lb9
Transmission: M20
Hers a easier to read flow chart for 43
http://www.chevythunder.com/esc_map_code_43.htm
Old Jun 30, 2018 | 06:18 PM
Camaro29's Avatar
Car: Camaro IROC 86
Transmission: 4L60
I wanted to change distributor from vette, drop it in trash and buy stock distributor from f-body 87-92. And than 42 and 43 errors will gone... But you want to tell me, that it will not help and i should not change distributor?
Old Jun 30, 2018 | 06:19 PM
Camaro29's Avatar
Car: Camaro IROC 86
Transmission: 4L60
Thank you. I will try to find out of this situation...
Old Jun 30, 2018 | 06:55 PM
Engine: Lb9
Transmission: M20
No need to swap out the distributor. It could be a bad ignition control module or wiring issue. You should try to fix it before swapping out the distributor.
Old Jul 16, 2018 | 02:59 AM
Camaro29's Avatar
Car: Camaro IROC 86
Transmission: 4L60
42 and 43 errors gone. Thank you.
New detanation knock sensor help us.
Jeff f
Sep 24, 2013 04:47 PM
doc
Alternative Port EFI Intakes
Dec 28, 2005 12:15 PM
jo88gta
Jul 14, 2003 08:08 PM
Vikingbrew
Feb 7, 2002 12:38 PM
