TPI head compatibility question
Old Jul 29, 2024 | 08:30 PM
92rs1leb4c's Avatar
Hello, I just recently purchased a 92 Camaro 5.0 TPI 5 speed. B4C and 1LE code car. I’ve looked through various threads and can’t seem to find a definitive answer, if there is one and I’m missing I apologize and just point me in the right direction. My current head castings are #187 which I’ve read are poorly flowing swirl port heads(?) I believe. I’m looking to find a better cylinder head that I can install with my stock tune port intake. Would an #081 cylinder head off of a marine 305 after so porting work be an upgrade that would still use my current intake set up? The plan is just a head, cam, exhaust build on a “budget” and if #081 heads work, I’ve found a few pairs for pretty cheap money.
Old Jul 29, 2024 | 11:08 PM
BHR's Avatar
BHR
Re: TPI head compatibility question
081 are the HO 305 TPI heads they will work
081 flow 185 110, 187 head flow 160 135
are you sure you have 187 castings? in 1992 all 305 regardless of option came with the good 773 305 cam I would of thought your option would come with 081 heads
Old Jul 29, 2024 | 11:10 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
May have swapped in a used engine to replace a blownup factory unit
Old Jul 30, 2024 | 07:10 AM
92rs1leb4c's Avatar
Is there anywhere else I can look to determine if the engine has been swapped sometime in past without disassembly?
Old Jul 30, 2024 | 04:28 PM
BHR's Avatar
BHR
look at bolts if they are marked up from being removed check the motor mount bolts
because your car starts life as RS it may be correct for it to have the those heads, I can confirm from parting out a 92 305 tpi non g92 did come with the better cam but that was a Z28 dont remember what heads it had
Goany
Nov 27, 2010 09:09 AM
BC GTA
Jan 25, 2009 11:51 PM
grimmcs
Jan 10, 2007 02:59 PM
bb454chvy
Feb 17, 2006 08:13 AM
irocbadboy
Aug 23, 2005 09:59 PM
