MAP Sensor
Old Sep 3, 2024 | 12:45 PM
Jayess's Avatar
Car: 67 GTO & 85 T/A & 2010 Vette
Engine: 400 CID 4 bbl & 5.0 TPI
Transmission: Turbo 400 & 4 Speed Auto
MAP Sensor
Can anyone show me a video on how to change the MAP sensor on my 85 T/A with TPI? please!
Old Sep 3, 2024 | 01:55 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: MAP Sensor
85 is maf
Old Sep 3, 2024 | 02:46 PM
Jayess's Avatar
Re: MAP Sensor
Thanks for the info. I would still like to see a video if that is possible!
Old Sep 3, 2024 | 02:48 PM
Engine: Lb9
Transmission: M20
Re: MAP Sensor
if it’s not on your car how can there be a video?
Old Sep 3, 2024 | 03:03 PM
Jayess's Avatar
Re: MAP Sensor
I don't get your response. I just got a code referring to the MAF. Was interested in seeing how to change it.
Old Sep 3, 2024 | 03:08 PM
Engine: Lb9
Transmission: M20
Re: MAP Sensor
The maf is in front of the intake bellows. Unplug its electrical connection and take off the 2 clamps. Might want to properly diagnose 33,34 or 36 if you’re getting any of those codes.
Old Sep 3, 2024 | 03:09 PM
Engine: Lb9
Transmission: M20
Re: MAP Sensor
your post says map, that’s not the same as a maf
Old Sep 3, 2024 | 04:36 PM
Jayess's Avatar
Re: MAP Sensor
I stand corrected!
Old Sep 4, 2024 | 05:23 PM
erik69&85's Avatar
Re: MAP Sensor
MAP - manifold air pressure sensor
MAF - mass air flow sensor
Big difference between the two ...cars that had one did not have the other.... MAF vs speed density systems....
SketchyZed
Nov 9, 2017 06:55 PM
v8nate92RS
Apr 6, 2005 10:31 AM
CHEVYTOWN
Southern California Area
Apr 12, 2003 04:02 PM
