350 TPI spark knock
350 TPI spark knock
I have an 87 350 TPI that's stock. I've tried everything to get rid of the spark knock. At spec 6 degrees timing it's severe. At about 2 after TDC it's OK. I have replaced distributor, ignition control module, cap, rotor, cooler plugs, MAF (relays are good), IAC, knock sensor (working OK), O2 sensor (single wire, faults when disconnected and bench tests OK). The TPS is set to 5.4v. Fuel pressure with key on, not running is 44psi and holds, then lowers to about 40 running at idle. Car runs like a bat out of hell and idles perfectly smooth at 600rpm, but under load I can't get rid of the knock.
I just removed the intake to fix an oil leak and found one of the hard vacuum lines crushed. Even that fix didn't change the knock problem. I also cleaned and tested the EGR and it's solenoid, both working well. Cleaned and tested all 8 injectors.
I understand running regular gas will cause some knock, but it shouldn't make it undriveable at spec timing.
Any ideas?
Any ideas?
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: No G92
Re: 350 TPI spark knock
So you had this condition before and after pulling the distributor to do the intake? And for clarification, you're setting timing with EST bypassed?
(check your decimal point in TPS value you wrote).
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Check TDC and the marks on the damper/pointer. The outer ring may have slipped and that would mess up your ability to correctly set the base timing.
Interesting thought about the timing marks.
This problem was there before the intake remove/repairs and there is no change. Setting timing with EST disconnected. Yes, you are right about the TPS. It's .54v
How do you know the car is stock?
What heat range spark plugs are you running?
What HEI module are you running (aftermarket ones can actually create significant offsets in the commanded spark timing).
Engine: LT1, L400
Doesn't the ECM control the timing once the car has started? I think it does.
https://www.thirdgen.org/forums/diy-...ncy-table.html
Engine: LT1, L400
So...it can only retard timing, then. Not visualizing how it could "anticipate" a signal from the ECM, and trigger the coil on it's own?
https://www.thirdgen.org/forums/diy-...ml#post3775917
Engine: LT1, L400
Huh. That sounds incredible. The ICM can anticipate a signal that hasn't been generated yet. How?
Your link took me to post #1. No Rbob there. I couldn't find the post that you must be referring to.
Engine: LT1, L400
I don't see any explanation in or around that post as to how an ICM can anticipate a signal that hasn't been sent to it, yet.
The 048 module, it held steady timing until about 3800 RPM where it retarded 4 degrees. Then by 5000 RPM the retard had increased to 6 degrees.
The 369 module, it held steady timing until about 3200 where it gained 2 degrees of advance. This held steady to 5000 RPM, which is the highest RPM it was checked at.
I pulled this out of his post.
Engine: LT1, L400
I'm not sure either...that's why I'm asking. I don't think that "mechanism" exists....or could.
Once the car starts, the ECM takes over timing. The ICM is a slave, a device that grounds the coil, then breaks that ground to create a spark -functionally, it's just like points used to do. The ICM get's the "Now-now-now-now...." (aka, the "timing") from the ECM when the engine's running, and it executes the grounding and breaking of the coils primary circuit. SO, that being the case, it's hard to understand how the ICM can interpret and modify the timing. Now, MAYbe, there is circuitry inside the ICM, that can delay (retard timing) the timed signal from the ECM.....though it makes zero sense since GM could retard timing all they want to w/in the ECM, but MAYbe. But even if that were the case....how can the ICM anticipate a signal it has not yet gotten, and go ahead and break the coil's primary circuit before (advancing timing) it's been told to?? A signal that has not yet been created or delivered to the ICM, by the ECM, yet. The "mechanism that I'm describing"....doesn't exist, -that's the whole point....so IDK how it's possible for the ICM to change timing -especially advancing it.
Engine: LT1, L400
Copy. I'd love to understand how that works. I can see a delay (retard) circuit in there....but I can't fathom a way for it to advance.
How'd you measure to "see" the retard occurring?
Car: '89 GTA
Engine: ZZ6TPI
I agree with checking the damper/pointer to confirm it is correctly indicating TDC. It's not uncommon for the outer ring on the damper to slip and rotate relative to the crankshaft.
I also agree with the question regarding whether or not the engine is stock. Unless you know all of the history of the car, don't assume it is.
Have the injectors been replaced and what are they? If they are original, they are shot by now and should be changed. If they've been changed, need to figure out what they are and what flow rate.
Check the casting numbers on the block (behind the driver's side cylinder head, where the trans bellhousing connects) to see what block is in it. Also pull the valve covers and get the casting numbers off of the cylinder heads to see what they are. The engine internals are who knows.
My '89 GTA with a 350TPI had audible spark knock under heavy load for a long time and tried most of the things you have done. It would start knocking on the 2-3 shift and continue while pulling 3rd gear. Everything was set up "stock". After a number of years, never really figuring it out, the headgasket let go. Tearing the motor down, I found it was in fact a 350, but not original to the car and had been rebuilt 0.040 over with stock replacement internals, stock spec camshaft. However, the cylinder heads were swirl port style from an L05 TBI truck or Caprice. That was more than likely my knocking issue. Swirl port heads have a faster burn than the TPI heads and require less ignition timing advance.
Moral of the story is to not assume your motor is stock, unless you know for sure.
Car: 1989 Pontiac Firebird Formula 350
Engine: 5.7 TPI
Axle/Gears: 9 Bolt 3:27
How long have you had the car? From when the problem started have you run multiple tanks of gas through it from different gas stations? Reason I am asking you may have received a bad/contaminated batch of gas.
It also may be caused by a mechanical problem (a cylinder that has a bunch of carbon built up, a wrist pin/piston problem, etc).
Car: 1991 camaro convertible
Engine: LS3
Transmission: 6l80
Axle/Gears: Ford 8.8 3.31 torsen t2r
I have always thought of factory timing specs as a starting point. I start there and then try to find what the car likes. That can change when other things change, like gear ratios changes.
I've had the car since February 2024, so many tanks of gas. I've also put a few cans of seafoam through the gas over that time. Everything seemed pretty clean at least what I could see when I removed the intake. I also cleaned all the carbon buildup off the upper and lower intake.
Engine: 5.7 TPI
How bad was the carbon buildup in the intake ports? If a lot then it also could be in around the valves and combustion bowl of the head. I recently bought an 89 Formula 350 and one of the previous owners routed the egr directly to manifold vacuum instead of the egr control valve. So it was getting egr anytime the manifold had high vacuum!
Engine: 5.7 TPI
I had an exhaust leak caused by broken studs that hold Y pipe to exhaust manifolds. I went to remove the exhaust manifolds to repair and the right rear manifold bolt broke off flush with the head. So now I have to remove the intake manifold and right side head to extract the broken bolt. I wonder how much carbon build up I may find. I was surprised when I pulled the Y pipe down that the inlet of the converter showed no carbon buildup and could shine a light through (no sign of any blockages)
Engine: LT1, L400
First, carbon shouldn't accumulate over time; carbon should coat parts initially, then the accumulation should occur at the same rate as the burn-off. Should. If carbon is accumulating progressively, there is something else wrong that is causing that to happen.
Second, you don't need to pull the head to get that stud out, if you have some resources, you can weld a nut on the broken bolt, and thread the bolt out.
Engine: 5.7 TPI
Two things that may be helpful:
Engine: LT1, L400
1.5" from the head, huh? It's amazing that the manifold fits in 1.5"...and you could get a bolt in/out.
Well? As you were, then. I'd weld that b!tch and get it out.
ImportsRsloths
Oct 13, 2002 01:55 AM
