Lb9 swap
Old May 2, 2025 | 08:49 PM
Bria's Avatar
Lb9 swap
My 88 t/a 305 tpi. Purchased a 1987 5.7 tpi out of a vett. Computer and all went into trans Am.. now it blows gas out exhaust. Runs good but smokes black smoke. Shop has no clue what's wrong
Old May 2, 2025 | 08:59 PM
ratfink6923's Avatar
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
Re: Lb9 swap
Sounds like you have a stuck open injector on the new fuel rail. A simple fuel pressure drop test should confirm
Old May 4, 2025 | 09:21 PM
Bria's Avatar
Re: Lb9 swap
thank you.. I ordered a pressure checker
I have been concerned that it could be wrong chip in the ecu..
Old May 4, 2025 | 10:27 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Re: Lb9 swap
Didn't the chip, come w/the 'puter...that came w/the engine?
Old May 5, 2025 | 08:34 AM
Bria's Avatar
Re: Lb9 swap
Yes sir. I got ecu and chip... Tried both in car.. it's just running rich and blowing black. I wish I hadn't swapped the engine now but we wanted a fun car. New plugs , wires, and cap. Sorry it took a while to respond. I'm learning how to use this site. Thank you
Old May 5, 2025 | 09:00 AM
Engine: LT1, L400
Re: Lb9 swap
It seems unlikely that the ECM from the 'Vette would have the wrong chip, for the 'Vette engine. I'd be investigating other possibilities. Do you have an OBD I scan tool? Can you data stream or data log?
Old May 5, 2025 | 12:06 PM
Bria's Avatar
Re: Lb9 swap
No sir. I'm wanting to buy a OBD1 reader. No cel on and shop that did the work said it had no codes. I do have a fuel pressure gage reader on way and now will look for a code reader. Thank you please don't give up on me.
Old May 7, 2025 | 10:16 PM
Bria's Avatar
Re: Lb9 swap
I checked fuel pressure and it's at 40 lbs. When I shut off car it doesn't drop. So that tells me it's not leaking injectors. But this thing is blowing black and drips fuel from exhaust. It runs good. Starts great and idles good but can hear it loading up..
Old May 8, 2025 | 12:06 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Re: Lb9 swap
Is it possible the fuel is not getting burned? valve timing off somehow, intake valves not sealing, some weird thing like that. or too much fuel being pumped in and a complete burn doesnt happen. all those add up to engine not running good tho.....
Old May 8, 2025 | 07:27 PM
Vader's Avatar
Re: Lb9 swap
If it is not a mechanically stuck injector, it could be an electrical issue. If one side of the injector harness is inadvertently grounded, the four injectors on that bank would spray fuel constantly whenever the ignition power is on.
Such a short could also be in the injector driver (transistor) for that ECM output.
69442DREAMCAR
Nov 12, 2009 12:31 PM
1bad88droptop
Jun 22, 2005 11:06 AM
LittleNo
21
Apr 25, 2005 07:20 AM
BuckeyeROC
Aug 30, 2003 02:29 AM
