305 TPI will start but not run (need some hints)
Old Nov 3, 2025 | 06:35 AM
  #101
tnorthardt's Avatar
Transmission: 5-Speed
Axle/Gears: 3.45
Re: 305 TPI will start but not run (need some hints)
Not sure on the abbreviations , I prefer tuner pro rt and $6e. It takes a swinging o2 and cts to be 165f or higher to get cl to occur.
we might be in a good place folks (fingers crossed). I forgot about the 10k mode with WINALDL so the idle was higher than I wanted. Without it, it seemed to settle around 750 RPM. I took it out for a few test spins and it seemed to be doing okay. Still might be running a bit rich. I'll replace the O2 sensor since it is 38 years old. I'll report back. thank you :-)
Old Nov 8, 2025 | 01:07 PM
  #102
tnorthardt's Avatar
Axle/Gears: 3.45
Hey Friends. I think we can consider this case closed. I replaced the O2 sensor (it was 38 years old) and it seems to be idling just fine. It is running really well. The original thread was about the stumbling idle. I think it was the vacuum leak in bottom rear intake runner I created when I replaced all the injectors. But, in chasing it down, I pretty much replaced everything! Thanks for all your ideas!
Summary: checked plug wires multiple times. they are numbered on both ends. new wires, new plugs. New distributor, cap, rotor, pickup, ignition control module, coil, IAC, TPS, MAF, EGR valve, PCV. New fuel pump, fuel filter, fuel pressure regulator, and injectors. Verified all plugs receive spark. Verified all injectors receive electrical commands with a noid light. Timing at 8 degrees advanced w/out EST - probably around 20 w/ EST. New O2 sensor. Running great!
Old Nov 9, 2025 | 06:19 AM
  #103
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Thanks for giving final feedback!
xFeveredx
Apr 11, 2015 06:38 PM
rowen25
Jun 10, 2014 11:35 AM
88gta_hiflyer
May 17, 2010 01:39 PM
PneumaticTire
Apr 18, 2010 01:38 AM
PAformula
May 14, 2009 11:44 AM
