SLP runner fitment
Old Oct 25, 2025 | 11:18 PM
Nicoirocz's Avatar
SLP runner fitment
Hello all
has anyone ever had any issues fitting your slp runners? Or has anyone had issues either the ARP lower intake bolt kit clearing your runners?
I have a set of Afr heads with the stock lower intake manifold. I used the ARP lower intake bolt kit to get rid of the torx button heads since most of my were stripped.
My SLP runners will not clear and fit. Only solution I can think of to get them to fit is to either grind with a file the head of intake bolts. Or grind around the bottom of the runners where it’s hitting the head of the bolt. Just wondering if anyone else has ran into that issue before and what they did to get there runners to fit.
Maybe remove the fuel rail and injectors then reinstall after the runners are in?
Old Oct 26, 2025 | 08:13 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: SLP runner fitment
Might be an issue with all tpi runners and hex head intake bolts. I didn't want to trim bolt heads and still have an issue or go find the OE torx ones. I had an issue with a set of edelbrock runners but I could sneak them in at the right angle with the injector rail loosened up a little. Made it all the more tedious to assemble the intake. Injectors and rail bolted down, bolt down the intake base, loosen the rail bolts far enough to pry some clearance for the runner, slip runners in their area, retighten the rail while checking for oring or injector seating issues. I'm happier with an HSR for a few reasons and intake install and disassembly ease is definitely on the list.
Old Oct 26, 2025 | 12:18 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
I don't recall any issues, but I used the factory bolts.
Old Oct 26, 2025 | 01:03 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
You'll have to grind the bolt heads till they are as short as the factory bolts are. You may even have to clearance the runners a touch.
Old Oct 26, 2025 | 05:57 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
If the bolts you are referring to are socket head cap screws then yes, they will interfere in a few places. You will have to grind the head and/or runner for more clearance. There is a reason why GM used the torx head pan head bolts on TPI.
Fred
Old Oct 26, 2025 | 06:36 PM
Nicoirocz's Avatar
Thanks all,
I’ll go ahead and grind down the head of each bolt and touch up the runners a bit to get them to clear.
JekyllandHyde
Jul 28, 2024 11:08 PM
Royal_Z
Jan 20, 2015 12:22 PM
66impalaTPI
Jun 8, 2006 08:58 AM
1988 Massz
Feb 8, 2005 07:09 PM
1bad91Z
Aftermarket Product Review
Nov 19, 2002 01:27 AM
