timing ?
Old Jan 28, 2002 | 09:29 PM
ScreaminDeamin85Z's Avatar
timing ?
hmmm where to start. I originally had the stock 19 lb injectors in my car and had it running pretty good. Well that didnt last long and I installed some svo 24 lb injectors that i allready had ( yes i know it wont run correct without proper PROM tuning) and i drove it like this for a few weeks but after messing with the timing and fuel pressure i decided to put the stock injectors back in because it ran better with them. well i set the timing and fuel pressure back to what it was in the beginning (4* BTDC and 48psi). When I "test" drove it earlier it bogged down and acted like it wanted more timing advance. I have adjusted from the 4* BTDC on up to 9* BTDC and it still had a studder in it but it wasnt nearly as bad. Should i try moving the timing farther up? or do i need to bring it back down around TDC?
Old Jan 29, 2002 | 09:53 AM
89BlueTA's Avatar
My car likes around 12.5-13 deg. of timing and I always run premium gas.
Old Jan 29, 2002 | 09:56 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Why not get into eprom burning? Simply increasing the base timing will often trigger the knock sensor. Controlling the spark advance curve in conjunction with the Knock Sensor will yield the best performance gains.
Also, it sounds like you need to play with the "pump shot" for "off idle".
Old Jan 29, 2002 | 10:17 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I hope you wernt running too rich with those 24lbs injectors. its bad for the rings..
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
