Dual Fan Setup???
Old Feb 2, 2002 | 09:45 PM
StocRoc's Avatar
Dual Fan Setup???
If I buy the dual fan setup off of a 350 TPI car, what else do I need besides the 2 fans?? Do I also need the upper and lower parts that the fans bolt to, or will my old ones work from the single fan setup?? The car is an 86 Iroc w/ a 350
Old Feb 3, 2002 | 09:16 AM
StocRoc's Avatar
Any help would be great, I need to know. Thanks
Old Feb 3, 2002 | 11:19 AM
Tyler-88's Avatar
if you buy a dual fan setup for your car, one would think that it should come with all the pieces?
Old Feb 3, 2002 | 11:44 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
you need the upper and lower brackets for the fans. you old ones' will not work.
Old Feb 3, 2002 | 05:37 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Ya, you need the upper and lower brackets.
About $35 or so new from the dealer for both parts.
You will also need another relay for the second fan, as well as a connector for the fan.
If you can't get ahold of them, I can get all the parts at my dealer and ship them to you.
Old Feb 3, 2002 | 07:47 PM
StocRoc's Avatar
thanks for all the help guys. I will let you know about needing those parts.
Old Feb 3, 2002 | 09:32 PM
Omar's Avatar
The lower bracket is part #10055083, $8.00.
I am sorry I don't know the upper bracket part #.
Old Feb 4, 2002 | 04:24 PM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
Go here and follow the link for the dual fan conversion. It's got part#'s, approx. pricing(for new parts), and directions.
http://www.metzlerracing.com/
Bubbajones_ya
Jul 6, 2024 08:32 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
scotrans am
Sep 5, 2015 04:26 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
