what do 1990 irocs use MAF?
Old Feb 5, 2002 | 05:41 PM
1bad350's Avatar
what does a 1990 iroc use to detect airflow ? does it use MAF and where is it located?
Old Feb 5, 2002 | 05:57 PM
89bonestockiroc's Avatar
Hey, you are lucky. You have the only year iroc with the speed density system. You have no maf sensor or burnoff relays to worry about. Instead of a maf, you have a map sensor connected to your intake by a vacume hose. I think its located at the back near the top of the firewall, but im not sure. But your car did come with the speed density system and I think that is considered most to be a good thing.
Old Feb 5, 2002 | 06:45 PM
360Iroc's Avatar
speed density
Old Feb 5, 2002 | 08:09 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
On my 90 Iroc the MAP sensor is located on the passenger's side of the plenum.
Old Feb 5, 2002 | 08:10 PM
1bad350's Avatar
thanks guys
Frozer!!!
Jan 19, 2024 04:55 PM
trevor1010
Aug 24, 2015 11:29 AM
chazman
Aug 22, 2015 02:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
mustangman65_79
Aug 11, 2015 03:17 PM
