Corvette heads
Old Feb 13, 2002 | 12:40 AM
914Mula's Avatar
Car: 91' Formula
Engine: 383CID
Transmission: t-56
Axle/Gears: 4.10
Corvette heads
Will corvette aluminum heads casting #10088113 work on my 91 L98? will any modifications be needed?
Old Feb 13, 2002 | 11:05 AM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Yes, they'll work on your L98.
You'll have to do 2 modifications, though.
1) remove the pushrod guideplates, because your motor has self-aligning rockers on it
2) You'll have to elongate the center intake bolt holes on your intake base because the aluminum 'vette heads use the "old" style bolt angles (all the same) rather than the newer (center ones canted less).
Old Feb 13, 2002 | 11:24 PM
Rosco the Iroc's Avatar
Car: '89 IROC, '14 LTZ Burb, '18 H6 Outb
Engine: 355 TPI /w Vortec
Axle/Gears: 9 bolt 3.27
Look at my thread under exaust and you need to also have a ext EGR hook-up.
Frozer!!!
Jan 19, 2024 04:55 PM
lt500r55
Sep 1, 2021 01:30 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
TreDeClaw
Aug 14, 2015 06:58 PM
