Best runner-base-plenum combo?!?
Old Feb 15, 2002 | 11:17 AM
GTA600's Avatar
Accel, Lingenfelter, TPIS, SLP, Edelbrock, Weiland, AS&M, stock.....siamesed, ported?????? Whats the best combo. I would like the siamesed I think and I dont mind spending a little extra money, I don't want to go with a LT1/Miniram/Superram manifold.
I assume the best combo will be one base with somone else's runners and a port job on top....
its for a 350 with AFR 195 heads 1 3/4" headers and a hyd-roller 224/230 cam with a 52mm throttle body 10.5:1 Holley Commander 950 ECU
on a side noe...what do you guys think of this....Im thinking of getting a 85 firebird and Im thinking 406 LT1 intake, AFR 220 heads, 230/236 HR cam/58mm throttle body 8.5:1 with Procharger 14lbs boost and Accel DFI with a ford 9" 3.45 posi, art carr 700r4, spohn suspension or I may go with the FP performance ECU for a sequential fire
Old Feb 15, 2002 | 05:02 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I know you don't want to hear it, but none of that crap is going to feed a motor that's got 195s. An LT4 intake or miniram would be the only 2 things I'd screw with.
That said... you want maximum flow if you ever have any chance of pushing the TPI's power range into the same area that those heads. Get any aftermarket base (they're all the same) port the **** out of it, AS&M siamesed runners, and ported plenum.
Of course, the aftermarket base and AS&M runners will put you pretty near the cost of a miniram.
Old Feb 16, 2002 | 08:38 AM
Lounge Lizard 6's Avatar
Ditto what Jim said. I did the Big Mouth base, ported plenum, SLP runners and I'm not happy with it. HP peak is a truck like 4800 rpm. I'm going the LT1/4 conversion as soon as I can scrape up the $$.
Old Feb 16, 2002 | 08:51 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Some one send me a F40 Z28 Wing and I'll give them a free modified LT1 intake and fuel rails.
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
roysatikas
Sep 22, 2015 08:15 PM
z28guy134
Sep 1, 2015 11:50 PM
