Can I use an old style cam with a 1990 distributer??
Old Feb 19, 2002 | 04:10 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I thought I heard something on a bronze gear or something??? Wrong??
Old Feb 20, 2002 | 11:00 AM
Car: 1991 Firebird
Engine: 427 LSX
Come on, someone knows this!!
Old Feb 21, 2002 | 01:10 AM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
You will have to change the gear on the distributor to the bronze one if the cam is earlier than 1985.
Old Feb 21, 2002 | 07:49 AM
Car: 1991 Firebird
Engine: 427 LSX
Ok, in design or make? It is a comp cams 292H. Purchased in 2000.
Old Feb 21, 2002 | 12:56 PM
72LT1VETTE's Avatar
Engine: 350 HO
Axle/Gears: 336
The type number "292H" and purchase date are not important. The 292H is a Street/Strip fairly radical cam that can be built for almost any year model vehicle. You need to find out what year and engine the cam was ordered/purchased for. This will determine which distributor gear is needed. You can call the Comp Cams hotline at 800-999-0853 or visit there webb site at; www.compcams.com They are very user friendly and helpful. Maybe not the answer you're looking for, but based on the info at hand, that's the best I can do.
Old Feb 21, 2002 | 08:44 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
You can use a distributor which has an IRON gear with most flat tappet cams, and even GM's TPI roller cams, as they are induction hardened and not billet steel.
A cam that is billet steel requires a bronze gear.
The newer iron gears GM made were for the different size distribut shaft. In the late 90's there was a close tolerance gear, and it was replaced with a harder verion for the vortec engines with high volume pumps.
So, yes you can use a 1990 dist. with an older, non-billet steel cam.
Mark.
Frozer!!!
Jan 19, 2024 04:55 PM
gta90
Sep 15, 2015 04:00 PM
lt1z350
Aug 28, 2015 05:57 AM
pimprs
Aug 24, 2015 11:20 PM
Dialed_In
Aug 20, 2015 01:45 PM
