Help porting the plenum
Old Feb 19, 2002 | 06:46 PM
Larry Dunlap's Avatar
Car: '91 Formula
Transmission: TH350 built
OK, I want to port my plenum and I remember a description on here, but before I take a grinder to my car I wanted to double check if I have it right. If I take of the air intake stuff and look into the throttle body with the covers open, I see a flat area on the bottom of each of the two openings, Immeditaly behind the round throttle body covers that blocks maybe 10% of the the total round opening on each one. The idea is to take off everything and use a dremel tool and grind this flatt area off until it is flush with the round opening, right? I have a dremel tool and it's plugged in, please confirm procedure doctor!!!
Larry
Old Feb 19, 2002 | 08:17 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
the TPIS catalog has a good example of a ported plenum: http://www.tpis.com/pg9-12.html
Old Feb 19, 2002 | 10:25 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
or:
http://www.gmtips.com/3rd-degree/dox...-port/port.htm
Reid Fleming
Oct 10, 2015 09:56 PM
toronto formula
19
Oct 6, 2015 12:27 PM
bplessy
Sep 30, 2015 12:14 PM
