Porting plenum...the front-sides question
Old Feb 21, 2002 | 09:22 AM
Little GTA's Avatar
The two throttle body holes in the front area:
I have finished porting the bottom area where the EGR (?) holes are. Question is how far can I port the sides. They flare in towards the middle and look like they impede air flow. Anybody know the maximum amount I can port this out?
Old Feb 21, 2002 | 11:19 AM
Guest
Guest
Posts: n/a
Its pretty thin as it sits. I wouldnt cut too much from that area, maybe 3/16" thick at the least. You can have it welded up and open it up somewhat. Putting a bigger TB on?
Old Feb 21, 2002 | 11:32 AM
Little GTA's Avatar
Is that a trick question? Gonna tell me I don't need a bigger throttle body?
No...putting on an Accel Intake, runners, removing smog equipment...and porting my plenum while I'm at it.
I can cut 3/16" at the most...or that's what you recommend I cut? Just want to clarify.
Old Feb 21, 2002 | 12:07 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I'm not sure on the early plenums, but on mine, there was plenty of meat there to smooth / radius the whole thing. You don't have to go nuts trying to open it up, it's pretty much a dead spot as far as flow. You just don't want to leave sharp edges that will add to the turbulence coming from the TB.
Old Feb 21, 2002 | 12:45 PM
Guest
Guest
Posts: n/a
Well if its just the stock TB, grind it to slightly larger than the size of the gasket for the TB. What I meant about thickness is you dont want the aluminum of the plenum to be any thinner than 3/16" when you are done, might be risky to go more than that.
Old Feb 22, 2002 | 11:38 AM
Vader's Avatar
GTA,
You can safetly go about this far:
This gives some more views:
Old Feb 22, 2002 | 04:12 PM
nblanchard's Avatar
I just rounded it out more when I did mine
Old Feb 22, 2002 | 06:40 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Here are a couple shots of mine:
I got quite a bit of material off of that area, but I was crossing my fingers the whole time.... I really had to tell myself to stop towards the end there! .... Porting that plenum is so....... addictive .....
Old Feb 24, 2002 | 01:39 PM
IROCKER's Avatar
The EGR walls were a piece of cake...took me a little longer than I thought to do them...but easy. The side walls though, I was so nervous I was gonna go through them and then be screwed for a plenum. So I played it on the conservative side and just did some mild radiusing on them. I figure as long as the EGR walls were gone, that was the biggest restriction anyway.
beastin91rs
Oct 9, 2015 07:38 AM
69 Six Pack
Oct 5, 2015 07:51 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
redmaroz
Aug 16, 2015 11:40 PM
mx127
Aug 10, 2015 08:13 AM
