Help! Car is possessed!!!
Old Feb 22, 2002 | 06:35 PM
Humvee's Avatar
Hey, I'll get to the point. When I'm accelerating, my lights dim and my tach goes nuts along with the voltometer even though it's revving up. The engine seems to be revving normally when the tach is showing all types of weird stuff. My car now cannot maintain 13 volts when I'm driving around. When I come to a stop, it'll drop to 8-9 volts and stall sometimes... At other times, mostly during the day after getting it warm, it'll maintain 13 volts and the idle would be were its supposed to
be.
What could it be? I don't know where its specifically coming from and after the radiator 'raping' that I had experienced a few weeks ago, I now know to look to you guys before getting myself into a bad situation... I think it's the alternator, but I'm not sure, thus asking ya'll!
Humvee
PS, think I should disconnect the battery to refresh the ECM and hopefully solve the problem?
Old Feb 22, 2002 | 07:23 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
It sounds like the alternator. Those things dont last worth a ****. Eventually, your cars voltage wont go up anymore, and will continue to drop untill its dead. I would go that rout first, and see if that helps. Im sure it will.
Good Luck!
Old Feb 23, 2002 | 07:27 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
My 86 T/A did the same thing. It was a wild light show with digital guages. I went to Checker or Autozone and bought a replacement regulator for my alternator for about 10 bucks.
You can see the disassembly here in an article I did on:
Polishing Your Own Alternator
Red 86 T/A 5.0 TPI (LB9/WS6)
~HyperTech Cap/Coil/Rotor/AFPR
~Derale Adjustable Fan Switch ~ 170° Stat
~Flow Matched Injectors ~ K & N Air Filter
~Ported Plenum ~ Pirelli 245/50/16
~SLP TB Airfoil ~ All Else Stock
Old Feb 24, 2002 | 09:55 AM
89BlueTA's Avatar
If you take you ALT. off, any parts place should be able to test it for you, and tell you if it is bad or not.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
