Large ball in fender?
Old Feb 23, 2002 | 07:45 PM
HotRod's Avatar
Car: 87 GTA
Engine: Eaton Supercharged 350 TPI
I am in the process of cleaning up the engine bay and want to put my coolent tank under where the battery go's on an 87 GTA. There is room if I remove this black ball that is hollow. Does anyone know what this is and if I can remove it? I think it has something to do with emissions but I am not sure. If I remove it will it throw a code? Thanks,
Tyler
Old Feb 23, 2002 | 09:15 PM
blowen90ta's Avatar
it is a vacuum resivor that i beleave assists the power brake system. i guess if i were you i'd plug the line and see how everything works.it dosent do anything for emissions
pete
Old Feb 23, 2002 | 09:27 PM
firbird's Avatar
correct me if i am wrong but isnt that for the cruise control because i know it does not have to do anything with breaks
Old Feb 24, 2002 | 02:46 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Vacuum reserve canister stores vacuum for when the power brakes or other vacuum assisted components need it.
If it is for the cruise control, then I am going to remove it, since my CC is gone now.
Old Feb 24, 2002 | 09:12 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
if is the the black plastic ball w/ a 5/32" vacuum hose connected to it then it is a vacuum reservoir for cruise control.
Old Feb 24, 2002 | 09:29 AM
LeftTurn1LE's Avatar
Are you guys sure its for cruise control? I don't have cruise, but I do have that ball. I've always wondered what it was.
Old Feb 24, 2002 | 09:47 AM
Car: 1988 IROC-Z
if its located on the drivers side(Camaros) underneath the charcoal canister then yes it is for CC.
Old Feb 24, 2002 | 09:57 AM
a73camaro's Avatar
I figured that it was for CC, I mean my GAWD, how can a softball size chamber with a 1/4" line back up a basketball sized chamber with 3/8" line.
Old Feb 24, 2002 | 10:14 AM
bjm323's Avatar
Car: '91 Camaro RS
That black plastic ball is a vaccum canister. It is for all vaccum acutated accessories.
Old Feb 25, 2002 | 01:10 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Yes, it's for vacuum-operated things like cruise control as well as HVAC controls, but not power brakes; if you'll look closely you'll see that the brake booster line goes straight to the intake.
Ed1LE
Sep 30, 2018 09:14 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
