MAP Sensor question
Old Feb 24, 2002 | 08:52 AM
SLOW91TA305's Avatar
MAP Sensor question
hey,
My MAP sensor on my 91 TPI 305 trans am shows 12inHG at idle. The MAP voltage is 1.70V.
Isn't this supposed to be 20 inches at idle? My book says its supposed to be 30-70 kPa...however that converts. Bad sensor?
My last question is where is this sensor located? Is it the one thats screwed into the bottom of my TPI Plenum?
thanks
Old Feb 24, 2002 | 01:52 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
No, the MAP is on the passenger side of the plennum, where the 3 vacum lines run into the plennum... you cant miss it, its a black box abou 3"x2", with a 3 or 4 wire connector goin to it.
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
soarestransam
Aug 24, 2015 08:15 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
squiggy2
Aug 9, 2015 09:30 PM
