diferences between Vortec and vette alum. heads?
Old Feb 27, 2002 | 03:12 PM
Steve86TA's Avatar
Car: To many to list
What are the main differeces between the two?Do they flow about the same stock #'s as iron?
Old Mar 2, 2002 | 03:29 PM
69TPI383's Avatar
The Vortecs flow quite a bit more than the Vette heads do. I don't have the exact numbers but they are considerably better. The Vortec heads are cast iron of course and also need a differant intake. The older style intake can't be modified to fit so it's best not to even try. It kills any advantage of the Vortec if you do get it to fit without leaking. The Vette heads take the older bolt angle intakes.
If you need new heads AND a differant intake (as in a swap for instance) then you can get the Vortec heads and an intake in a kit for about $700. The heads can be had in stock or upgraded form for higher lift cams.
It may sound like I'm selling Vortec head. I'm not. I have a set of the Vette heads and really wish now I'd gotten the Vortecs since I had to buy a new intake anyway!
Old Mar 2, 2002 | 07:00 PM
87transam5.7tpi's Avatar
I have a pdf of what a bunch of heads flow. if you want it let mek now.
Josh
P.s. the vortecs flow ALOT better.
84z96L31vortec
Aug 20, 2017 12:16 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
z28addict8490
Sep 5, 2015 03:56 PM
earlpote
Aug 28, 2015 10:42 AM
86White_T/A305
Aug 17, 2015 12:16 AM
