Estimated power
Estimated power
Can someone help estimate my power and torque? I have a 92 gta with superram intake, runners, and base, 58mm tb, k@n cold air intake, trick flow aluminum heads, high performance cam, headers, flowmaster exaust, and a custom chip.
Just incase you were wondering its also got subframe connectors, new controll arms and panhard rod, stiffer swaybars.
The engine sounds great and really comes alive above 3000rpm.
Car: 91 Firebird
what are the specs on the cam, what kind of engine is it, what sort of Trick Flow's do you have, shorty headers or full length? Give more detailed info otherwise it'll just be a guess from the crystal ball.
Go to a track...make a few runs, and with your ET and MPH you can estimate your power. Otherwise...only a dyno run will get you real numbers.
A G-tech can get you in the ballpark if you can borrow one from someone.
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Anywhere from 350 to 420 HP depending on things like compression ratio, size of heads and cam, running condition, driver, etc...I agree it's just a rough guess without more detailed info.
sailtexas186548
Aug 24, 2015 10:11 PM
