Old heads on 350 TPI
Old Mar 8, 2002 | 09:50 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
what kind of heads can I put on my 350 TPI, and still use the stock base?
Can I use old style heads? Will I have to redrill the bolt holes in the base?
I would like to change the heads but not buy an new base.
Old Mar 8, 2002 | 10:14 AM
tpi_roc's Avatar
If your base is newer than 87 and you use "old heads" you'll have to elongate the center holes in your intake.
Old Mar 8, 2002 | 12:31 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
the motor is a 92 tpi. would older style heads be a good hp upgrade for my motor.
They are easy to get and can build them just as cheep.
Old Mar 8, 2002 | 12:44 PM
tpi_roc's Avatar
For the work... no not really...
Port the ones you have or go aftermarket
unless they're vortecs GM casting gen 1 heads all make limited power, vortecs still being only slightly above average.
Old Mar 8, 2002 | 02:04 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
What kind of increase will port & polish, bowl work and bigger valves do for my stock heads? Is it worth it to spend money on the stock heads?
Is it possible to get my car into the high 13's with work to my stock setup.
I dont want a full out race car, I just want to make noticably more power than stock.
thanks for any help you can give me.
NinjaNife
Aug 23, 2015 11:49 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
