Which sensor used in a MAT relocation?
Old Mar 17, 2002 | 11:04 AM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
Im sure this has been asked before but I couldnt find it under a search, but when relocating your MAT sensor what cars do you get it off of?
thanks
Jack
Old Mar 17, 2002 | 11:10 AM
u r sofa king we tah did's Avatar
go to autozone and get a coolant temp sensor. thats all it is. same part.
Old Mar 17, 2002 | 11:58 AM
monte-ss's Avatar
coolant temp and air temp are not the same, the one Im looking for is the one that snaps in to the plastic Ive seen this andread about it on here just cant remember which car it comes off of
Old Mar 17, 2002 | 01:29 PM
i hate to tell you this but yes they are the same. same part number, same part, same connector plug in. and seeing as how i relocated my MAT with a coolant temp sensor for an 88 corvette and it plugged right in, it works.
Old Mar 17, 2002 | 07:21 PM
topdown's Avatar
You need a MAT sensor for a 92 and up TPI/LT1..NOT a coolant temp sensor. Leave your current sensor in. I recomment TPIS relocation kit for $35....comes with everything you need and the new wire harness has a nice heat sheild on it...well worth the price.
Old Mar 17, 2002 | 07:30 PM
monte-ss's Avatar
thanks thats what I needed, I actually dont have to extend anythine with the set up I have, I have a harwood cowl induction hood and made an air cleaner for it, so Ill put the air temp sensor in that and the plug should be just the right length.
Old Mar 17, 2002 | 10:18 PM
trust me its the same part, i just picked one of these up not too long ago. check out autozone.com, its the same part number and the same part.
Old Mar 17, 2002 | 10:23 PM
monte-ss's Avatar
the sensor Im looking for is not a closed element sensor like the stock screw in MAT or the temp sensor, its a plastic open element sensor for faster and more accurate reading od the incoming air.
Old Mar 18, 2002 | 01:23 AM
that explains it better.
Old Mar 18, 2002 | 06:05 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
ive got the TPIS peice, very nice and inexpensive, and its the upgraded plastic sensor.
customblackbird
Oct 1, 2015 04:30 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
F-body-fan
Sep 19, 2015 09:02 PM
IROCZDAVE (88-L98)
Sep 17, 2015 05:46 PM
89newfun
Sep 16, 2015 09:28 AM
