Intake manifold
Old Mar 19, 2002 | 12:27 AM
kokki's Avatar
Intake manifold
Doest the intake manifold from the Corvette '89 fit to my Camaro Iroc-Z (305) '88? Is that change smooth or should I do some drilling?
How abaut the plenum from the Corvette '89 to that same Camaro Iroc-Z (305) '88? I read that there I should do some drilling for the IAC? Is there anything else..?
Old Mar 19, 2002 | 05:26 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
If you're talking both are TPI intakes then don't bother.
Old Mar 20, 2002 | 07:50 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I wonder how the people using the LT1 intakes are dealing with this problem?
J
Old Mar 20, 2002 | 08:42 AM
Swapmaster's Avatar
The intakes are the same except for the IAC and the mounting
area for the MAP sensor. Leave it alone.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Blue419
Sep 10, 2015 01:03 PM
BOOT77
Sep 5, 2015 03:55 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
