L98 Corvette Heads vs. F-Body heads
Old Mar 19, 2002 | 07:59 PM
91FormulaCRAZY's Avatar
Hi guys I'm new here. I just wanted to ask, what are the differences between the Corvette Aluminum heads and the F-Body cast iron heads besides the fact that one is aluminum and one is iron? I have an L98 Formula and want to do the swap. I'm keeping all of my emissions equip. What should I watch out for? Will there be need for special fabrication? Can I just get a set of new heads from a GM dealer? If so, what are the part numbers? Thanks.
Old Mar 19, 2002 | 09:02 PM
Blackened's Avatar
Don't bother. You'll see minimal power increases if any at all. I'd spend my money on a good aftermarket head.
As for the differences... they have better springs, screw in studs and guideplates and a smaller combustion chamber of 58 cc
Old Mar 20, 2002 | 03:06 AM
Bort62's Avatar
The 'vette Heads Don't have EGR passages.
Old Mar 20, 2002 | 08:00 AM
TBIWorks's Avatar
the intake bolt holes are different too aren't they?
Old Mar 20, 2002 | 09:12 AM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
yeah the bolt holes are different I found that out the hard way oh well, yeah should have gotten aftermarket heads instead of these ones.
Old Mar 20, 2002 | 12:45 PM
tpi_roc's Avatar
The corvette heads have 58cc combustion chambers and will raise compression, they have lower thermal efficiency thus you can run more timing per compression, and they have D port exhaust which flows higher numbers, they can be ported and modified to be very competitive, read up on what lingenfelter has done with them, its impressive.
Old Mar 20, 2002 | 07:38 PM
89blackbird's Avatar
What are the opions without the EGR crossover? I have a set of these I am going to put on. Do you have to have the crossover? The center two bolt holes on the intake are the two that you open up right???
Old Mar 20, 2002 | 08:48 PM
tpi_roc's Avatar
It depends on local emissions
If that isn't a concern then I say be happy you dont have one carboning up your intake
lt500r55
Sep 1, 2021 01:30 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
gixxer92
Sep 1, 2015 04:32 PM
zayne0
Aug 24, 2015 07:22 PM
TreDeClaw
Aug 14, 2015 06:58 PM
