whats difference between 3.8's?
my freind has a 86 bonneville with a 3.8
and it pulls suprisingly nice for being n/a
is thier any differece between this block and say the regal or TTA
version?
piston top, heads,crank maybe?????
thanx
i just changed the starter on this and noticed the individual exhaust collectors comming of the head,damn!
i dont even want to mention to my freind it could possibly keep up with my anemic TBI 5.0 LOL
version?
thanx
The front wheel drive block uses a different transmission bell housing configuration, not interchangable.
I know what you are thinking.
hehe
yeah well im constantly tossing ideas in the ol noggin
what kinda trannys did these cars get?
i think its a 700r in the bonneville
its seems like its got a 2.73 gear ratio too
just like my bird
2k at 80mph
so not posible to mate 3.8 fwd block to a 5 or 6 speed?
just like my bird
2k at 80mph
The Bonneville is front wheel drive, It uses a TH440 tranny, There
is no rear wheel drive tranny that will hookup to the Bonneville
engine, but there are adapter kits to make the swap possible.
ok heres the thoughts
finding a 3.8
hooking it up in a 6cyl bird or camaro and using forced air induction,better suspension etc.......................
mating the 3.8 to a t-56 using the adapter
i guess a custom drive shaft would be needed?
finding a 3.8
Actuall I think the 2.8 and 3.1 V6 use the same bell housing
pattern as the front wheel drive engines, but the flewheel
won't bolt to the converter which will give starter issues also.
Tomorrow I willl put a 2.8 Camaro bell housing up to a 3.8
frontwheel drive motor and see if it will bolt up.
If so, it would be possible to use a supercharged Bonneville
motor in a Camaro or T/A with some major work as the FWD
motors have no provisions for motor mounts on the sides of
the block.
the block.
Tallboy,
If you really want to swap to a V-6, consider a 262 inch Chevy even-fire Six for a few reasons:
Same bolt pattern as the SBC;
Same balance shaft as the 231 Buick;
Better parts availability;
Uses stock transmissions, starters, pistons, rods, and flywheels;
Can be bored and stroked to a 4.7 - 286 stroker,
or bored up to 282 with stock storke, The Buick can only be increased to 236 inches before you throw away the block;
Can be turbo or blower charged;
Can be built with aluminum block and heads;
Better selection of camshaft profiles (Comp stocks 26 different cams for the 262, only 3 for the Buick 231);
More intake choices, torque converter choices, starter options, water pump possibilities, fuel pumps, mounting configurations, yada, yada...
Yes, the Buick is a nice little engine - if you want a little engine. I don't want to start flames with the guys who have and like them, since it is probably one of the best corporate engines GM has in it's class. It's just that you can run the same boost on the larger engine and get proportionately more power. Just saying....
Ain't gonna work.
No Way, no how.
It will not bolt together, the dowel pins are not in the same
places and the configuration is just too far off and I have never
seen a kit for this kind of swap.
No Way, no how.
#1whats the bore and stroke oof the 262 v6?
#2would the 2.8(3.1) intake manifold fit the 262?
#3what vehicle(s) was the 262 found in?
#4did it come with a roller cam?
#5what liter is the 262?
#6 can the winadl program be used on 6cyl ecm's?
id think it be awesome to pull up next to a stang boy or import boy and not have the rumble of an 8 an makem see tailights
in a 3rd gen f-body of course
thanx alot
GOOD INFO -keep in coming
thanx alot
Well, the 262 in my '89 S-10 is 4.3L same bore/stroke as a 350. Actually, everyone over on an s-series board says they just took a 350 and removed the 7 & 8 cylinder. A little more complicated then that, but they based it off the 350.
Whoops, didn't realize this post was 2 months old
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
What about a 3.8L out of a 4thgen? What block do they use? Clearly they use the 4L60E tranny in that configuration, so there's GOT to be a way to make it work. Hell, If the 3.8 in my Olds ever goes, I was thinking about finding out if that swap will work.
yeah thats an idea
but are the motor mounts in the same spot?
ive done maintenence on a new 3.8 and it wasnt fun
plugs were almost impossible to do
when changing oil filter it leaks oil on sum parts because the filter isnt on like an 8,its on horizontaly near steering linkage
although the plug thing wouldnt matter with sum headers
and the oil filter spillage can be manged by jacking the oil collector closer to the filter
i wonder if the t56 would work with the new 3.8????
is the bore and stroke combo the same as the old 3.8?
Numbah-1
Sep 12, 2015 08:57 PM
