SURVEY: 1/4 mile times of tpi 305&350s
Old Mar 23, 2002 | 07:15 PM
jerflash's Avatar
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
I would like to know what times you my fellow tpi guys are runing i just went to the track at EnglishTown today and i ran
a 14.86@89.54mph (with the mods i have shown)and that is mush faster then any of the other 305 tpis that where running there. all the other 305 tpi firebirds and camaros that were there were runing 15.60
i would like to know what time your guys are runing with what engine and mod you have.
thank you very much
lates
Old Mar 23, 2002 | 09:29 PM
Hodge's Avatar
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
14.808 @ 93.5
305TPI IROC 5-speed 3.45 gears with minor mods below.
Old Mar 23, 2002 | 10:01 PM
Z_Ghost's Avatar
92 Z/28 350 auto 3.23 posi.
140,000 miles
Hotchkis suspension, air foil, msd 6al and drag radials
Ran 13.851 @ 98.16 mph.
Old Mar 23, 2002 | 10:07 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
here you go:
Old Mar 23, 2002 | 11:27 PM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
I pulled a 14.345@96mph in my vette with nothing more than a fresh tune-up and a k&n. And i'm not the best stick driver, so......
Old Mar 24, 2002 | 10:13 AM
87transam5.7tpi's Avatar
14.2 at 97mph, that was just with the catback and k and n I haven't had a chance to test it out with the rest of the mods.
Old Mar 24, 2002 | 10:22 AM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
Well I never ran the GTA stock BUT my 1985 corvette BONE stock including tires ran 14.08 96 MPH ... It was 65 degree day...The car had nothing except I think I modified the MAF and bumped up the TPS to like .62.... But thats not exactly any real mods...
Its a 700R4 and dana 44 with 3.07rear..
Old Mar 24, 2002 | 12:06 PM
Jono's Avatar
wow 14.86 with only 89.6 mph what kind of 60 ft are you pulling?
i only got 15.20 with 91.7 mph with a horrible 2.4 60ft.
Time for me to look for traction.
mods: 85 305tpi
catback
headers
k&n
hi-flow cat
Old Mar 24, 2002 | 12:43 PM
Casey'91Z28's Avatar
14.68@96 mph 305 with bolt on mods below except for afpr and cold air induction
Old Mar 24, 2002 | 12:54 PM
88 IROC BOB's Avatar
My best was a couple of years ago with limited mods. 13.88 @ 101.18 mph with a 1.95 60 ft. That was on street tires too!
Bob
Old Mar 24, 2002 | 01:06 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
14.603 @ 93.12mph 1.98 60' . With parts below with a plus sign. Traction is the key.
Old Mar 24, 2002 | 02:49 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Times and all my mods are in my sig, my setup is similar to yours jerflash... My best et which is below was on a worn clutch and 2 bad injectors... shell be fixed in a week, some new times comin up in a few weeks after I BREAK in the new centerforce!
Old Mar 24, 2002 | 04:54 PM
jerflash's Avatar
when i ran yesterday my best 60' time was 2.02 and that is with a 9bolt rear with 3.45 gears and i could not launch hard at all because the rear is i one legger now i had to feather it out of the hole i would rev the converter to 1500 and feather it and i got that time with a little tire spin if i fix my posi,put drag radials, and do some suspention work like control arms and panhard rod im sure i can launch much harder and actualy use my 2500 converter im sure i can run a 14.50 or less if i do this
and i shifted every gear manualy at like 5300-5500 and got the best results
Old Mar 24, 2002 | 05:57 PM
87 B4Z's Avatar
87 305 auto and 2.73's
SLP 1 3/4 headers
SLP 2 on the left cat back
Hypertech thermomaster chip
Free mods
14.9@90.8mph
Old Mar 24, 2002 | 06:58 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
X
Old Mar 24, 2002 | 07:03 PM
89BlueTA's Avatar
Y
Old Mar 24, 2002 | 08:07 PM
Adam62083's Avatar
In sig.. Best run was on a lipping transmission and bad rear end. I am assuming 13's are attainable with a tranny working at 100% instead of slipping on my shifts.
Old Mar 24, 2002 | 09:47 PM
Jono's Avatar
jerflash what kind of tires are you using? Just wondering.
Old Mar 24, 2002 | 11:54 PM
CamaroX84's Avatar
Mods/time in sig. This was on Mickey Thompson Pro Street Slicks (basically just like slicks). Best 60' time was a 1.850, and the slicks were still spinnin.
Old Mar 25, 2002 | 12:01 AM
jerflash's Avatar
i am runing bfg comp t/a's 245/50/16 all around
the backs only have a few thousends left
i need new tires
nothing speciel
and i have no suspension mods at all
if i mash the petal down the right tire spins for ever you just need to know how to lauch with out spining tires
this was my first time to the track also
Old Mar 25, 2002 | 12:14 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
14.74 @ 93mph, 2.13 60', mods are in the sig.
Should be running better with re-programmed prom, still working out the bugs on my LG4 to TPI swap.
I actually feel really slow compared to you guys, with the amount of mods I have and the slow performance.
Old Mar 25, 2002 | 02:31 AM
Jono's Avatar
Must get Comp T/A's!!! hehe I'd love to get near 2.1, these all season goodyear tires are horrible.
Old Mar 25, 2002 | 08:00 AM
92superram's Avatar
my time is V, that was with worn out Mickey Thompson's, i hope it's a little faster with my new tires. i forgot the speed,
Old Mar 25, 2002 | 02:20 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
14.4 @ 96.8 mph
305 TPI 5 speed, 2032 cam, siamesed base, AFPR, 1 5/8" headers, high flow cat, flowmaster muffler, SLP chip, home made intake, 3.42 gears, no traction (2.2x 60')
Probably ~$1500 in mods.
14 flat and 99-100mph will come with tuning.
Old Mar 25, 2002 | 05:18 PM
Wes B.'s Avatar
15.93 is the best I could muster out of my 87 Iroc 305, auto, and 3.42s. Traction was my major problem, and the lack of practice (only had the car a month). I ran 2-16.3s and 1-16.4 and one 15.9. Hopefully with some new tires (245/50 instead of 205/55) some headers, Y-pipe and Air foil I'll be doin tons better. Let's hope.
Wes
Old Mar 25, 2002 | 06:34 PM
TPIterror's Avatar
Car: Formula
Transmission: M5
14.06@98.8 mph
Headers exhaust and bolton stuff, but stock heads, cam, and gears. Street tires and 62 degrees.
Old Mar 25, 2002 | 06:35 PM
TPIterror's Avatar
Car: Formula
Transmission: M5
whoops! Thats a 305-5spd.
Old Mar 26, 2002 | 12:46 PM
jerflash's Avatar
are you sure you did not bolt on some nos to that bi*ch
because with street tires thats a really good time for a 305 5 speed
what are your stock gears
when i get some drag radials and fix my posi i sould be near 14.40 i think
Old Mar 26, 2002 | 12:51 PM
Jon98's Avatar
jerflash,
i don't want to start a flame war, but you said your car ran 14.8's, but yet claim to smoke LT1s?? or is that time b4 your mods? i know stangs are dogs but lt1's are pretty quick, mid 14's at WORST from what i seen, 14 flats stock usualy
curious....
Jon
Old Mar 26, 2002 | 01:31 PM
Kandied91z's Avatar
last run was 12.9 at 109
cold air, exhaust, and a 50 shot.
now i just need some slicks.....
Old Mar 26, 2002 | 02:53 PM
RedIrocZ-28's Avatar
Car: Iroc-Z
Engine: 355 AFR'd HSR
My best ET was a 14.75 I guess. The timeslip showed otherwise but my buddies watching said the screen read a 14.75. MPH?? Dunno. But my best was 96mph I guess. I had SFC's, Flowmaster 80 series, shift kit, 3.73's, !MAF screens, K&N's...... And I could launch too. All but a few of my launches last year were in the 2.0x range. Car had a few problems I guess, I should have been way faster than that.
Old Mar 26, 2002 | 03:32 PM
whiteroc's Avatar
See sig for mods and times...
Old Mar 26, 2002 | 04:29 PM
jerflash's Avatar
i have beaten a couple and i have lost to a couple the lt1s that i beat the people prob. could not drive but i have beaten a few
the fastest 80's mustang gt a saw at the track that day was runing a 16.20 and it was so funny
Old Mar 26, 2002 | 04:47 PM
polishdevil's Avatar
Car: 88 GTA
Time for some laughter. With my assummed 200K 305 TPI auto i ran a best of 15.8 at 84.1 with a 60 ft time of 2.287.
I'll let you guys know what i run with the 350 and stuff, if i get to go to EnglishTown tomorrow, hoping for real low 15 or high 14.
My buddy with a bone stock 2001 Mustang auto ran a 14 flat at like 99, he ran 13.9 at 100 with a ravin mufflers.
Dave
Old Mar 26, 2002 | 05:05 PM
jerflash's Avatar
i ran a 14.86@89.6 mph with a 305 and you can look at my sig i only have bolt on sh*t you sould derinatly get into the 14 if you have some tracktion
Old Mar 26, 2002 | 05:24 PM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
I was my first time at the track and no mods.
Old Mar 26, 2002 | 07:28 PM
Ski89Z28's Avatar
It is in the sig.
Still needs tuning I didn't play with that yet.
Old Mar 26, 2002 | 08:51 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
Last summer I ran 14.4s and hit 96mph for the first time. My best ET of 14.41 was on a different cooler day. I have all basic first and cheap mods, running BFG Comp T/A's, getting worn. I still have stock heads and exhaust manifolds. Done some tranny work and recently porting and gasket matching the base manifold. Also major computer PROM tuning. I am going to run this spring and see how she goes, then the 3.73's are going in. Hoping to hit the 13 bracket then.
Old Mar 26, 2002 | 08:58 PM
JAY87GTA's Avatar
123,000 miles, ran a 9.36 at 77mph in the 1/8th. Mods are in my sig. I was getting bad knock counts from a header flange that was hitting the crossmember and the fuel pump was on the way out. Getting it all fixed as soon as I get some more stuff from Summit! Just gotta find the time, so hopefully a 9.0 is just around the corner.
Old Mar 26, 2002 | 10:29 PM
bryanwhite's Avatar
My best time is a 14.6 @ 95 MPH with a 2.2 60' time...
1989 Formula TPI 305, 5sp, 3.42 gear, SLP 1 5/8 headers, dual hi flow cats, SLP cat back exhaust, rebuilt 305 (forged pistons, decked block and balanced) adjustable fuel press regulator, mild cam, holley fuel pump, and a little cylinder head work.
Old Mar 27, 2002 | 11:27 AM
Murt TTA's Avatar
Car: 89 TTA
Engine: 3.8L turbo
Transmission: 200r4
My 87 305 auto Iroc-Z ran a best time of 15.0@91MPH. It had K&N's, Flowmaster 2 chamber muffler, no cat, 3.42 gears.
~Murt
89 TTA
Old Mar 27, 2002 | 04:18 PM
  #42
85transamtpi's Avatar
My '85 had a best time of 15.0 @ 91.5...but that was before high flow cat, cat back, and trans rebuild (wasnt shifting into 3rd @ wot). I am positive the car is currently a high 14 second performer, but no slips to prove it.
P.S. its for sale
Old Mar 27, 2002 | 04:48 PM
  #43
3504mula's Avatar
Car: 90 Formula
Mods and times are in sig. But I was just wondering if everyone understands that times from different tracks and days will make some cars seem fast or slow...
I just didn't want anyone to think their car is slow b/c a car with the exact same mods as them is running a half second faster.
I know I took .2 off my time just by waiting till the weather cooled down a bit.
Not to mention the elevations of different states...
Maybe everyone knows all of this, so I'll shut up now.
Old Mar 27, 2002 | 07:54 PM
  #44
TPI Monte SS's Avatar
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
I have an '87 LB9 305 in my Monte SS, with the following mods -
Crane Roller 2031 Compucam, World Products S/R Torquer 305 heads, SVO 19lb. injectors, Edelbrock headers, air foil, !MAF screens, K&N cone filter, shift kit, posi, and 3.73 rear.
Any time I race, its on my 245/50 16 BFG Comp T/A street tires. My best run with her so far is a 15.0 @ 93 mph, with a 2.4 60' time! If I could launch without wheelspin, I could be in the mid-high 14s.
Must...get...new...torque converter!
Old Mar 27, 2002 | 08:15 PM
  #45
ThirdGenZ28 92's Avatar
Car: 1992 Z28
Engine: Stock L98 with bolt ons.
Transmission: Stock rebuilt tranny with 2k stall and cooler.
My best to date is 13.521 on a 1.770 60ft at a pathetically low 94.x MPH. This is with stock internals, mild tranny work, boltons only and some suspension pieces and was thru the manifolds and stock rear at 3688lbs with driver. Since then Ive added SLP 1 3/4s and !AC but Im yet to run a better ET but Im not done yet....
Old Mar 27, 2002 | 09:32 PM
  #46
91RamAir Formula's Avatar
Car: 91 Formula
Engine: 383 HSR
Transmission: 5th 700R4
Axle/Gears: 3.89
13..65@100 is my best 2.01 60' mods in sig
Old Mar 27, 2002 | 10:35 PM
  #47
Car: 88 GTA
Went to the track tonight and ran a best of 14.8 at 90.97 with a 60 ft time of 2.187. I had 2 problems: 1 totally no traction, my best run started out with smoke and going sideways, 2 the tranny didn't want to shift from 2nd to 3rd, my 1st and 3rd run I had to let off the gas because I was doin about 70 in 2nd at 5500rpm and it wouldn't shift, i let off the gas, dropped 3-4mph and then it shifted. I lost a lot of time doing that.
Dave
Old Mar 28, 2002 | 10:31 AM
  #48
Shaun 90 Iroc's Avatar
Car: 1990 Iroc-Z
Engine: 350 L31 Vortec
My Best so far is a 15.2 @91mph... 2.2 60 ft. this is on bald street tires and with my tranny slippin.. Only mods are 80 series exhaust, hypertech chip, coil and plugs, and a hefty 140,000 miles.. otherwise stock. I had Jamex foam old filthy filters in it. This was my first day out at the track racing. Only made 4 runs in my life.. Don't want to kill the trans that slippin until i have more money.
1990 Iroc-Z 305 A4 2.73
http://shaunsiroc.fbody.com
Old Mar 28, 2002 | 09:42 PM
  #49
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
Just got my custom chip reprogramed after runnin' slower than the sig.Hoping for 13's nxt fri night @ Cecil County.
BD3:hail::bowtie:
Old Mar 29, 2002 | 06:31 AM
  #50
lyonsd's Avatar
14.48 @ 95.6 May 1990 at Gateway International Raceway. Bone stock '88 Mustang GT 5-speed fully loaded and with the "economy" 2.73 rear gears and original worn-out "Gatorbacks" (same tires as when I bought car 2 years earlier, now with 43000 miles on them).
14.31 @ 98.3 April 1991 at Gateway. Same car as above with another year's worth of wear on the tires (57000 miles) but this time with Hypertech Power Module.
13.89 @ 98.9 June 1992 at Gateway. Back to stock chip due to converting to "mass air", 3.73 gears, 65mm throttle body, MAC off-road exhaust, underdrive pulleys and failing stock fuel pump.
13.13 @ 108.1 April 1993 at Gateway. Same as above but with new 110 lph fuel pump and NOS kit #5115 (75hp nitrous shot).
14.12 @ 96.4 October 2000 at Atlanta Dragway (Commerce). '87 Buick GN with K&N & Terry Houston downpipe. No posi and a crank sensor problem attributing to excessive knock retard and killing top end.
