will 2.8 manifold fit 4.3?
Old Mar 27, 2002 | 12:56 AM
Tallboy's Avatar
#1would the 2.8(3.1) intake manifold fit the 262?
#2whats the bore and stroke of the 262 v6?
#3what vehicle(s) are the 262 found in?
#4did any come with a roller cam?
#5 can the fpr be made adjustable?
#6 can the winadl program be used on 6cyl ecm's?
Old Mar 27, 2002 | 11:24 AM
DSaylor's Avatar
#1- no, 60* vs 90*
#2- 4" x 3.48" ( same as 350)
#3- astro/safari minivans, s-10's, full size trucks, full size vans, mid-late 80's monte carlos, blazers, not sure what else.
#4- some 86's and later
#5 & #6- ?????????????
Old Mar 27, 2002 | 11:37 AM
Tallboy's Avatar
is there any F I intake manifolds that will fit the 4.3
besides aftermarket?
what bout the 3.8 or the 3.3 manifold?the 80's-early ninties kind
Old Mar 27, 2002 | 09:32 PM
Swapmaster's Avatar
#5 - Yes
#6 - ??
Old Mar 28, 2002 | 03:13 PM
cfabe's Avatar
You might look into the multiport 3800 fuel injection manifolds. I'm not sure if they'll fit but at least theyre both 90 degree engines. I think the 3800 is related to a 305 in the same way a 4.3 is related to a 350. Maybe they share external dimensions like a 305 and 350.
Old Mar 28, 2002 | 04:02 PM
HotRod's Avatar
Car: 87 GTA
Engine: Eaton Supercharged 350 TPI
You can run a TBI or a CPI out of an S10, Astro van, etc. I personally like the CPI. I would imagine you could also run the injection off of most 3.8s like the new camaro's possibly? I am not for sure on that last point though.
Old Mar 28, 2002 | 04:06 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
The 3800 is a Buick engine. It won't interchange.
anesthes
42
Oct 24, 2015 07:30 PM
transaero
Aug 31, 2015 01:14 AM
theurge
Aug 21, 2015 12:46 PM
timonator
Aug 11, 2015 09:56 PM
