rce or av gas through injectors?
Old Mar 28, 2002 | 12:31 PM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
I was wondering if this is possible, I know you cant use leaded fuel in injectors but Im not sure what the differences are in race formula or aviation fuel.
thanks
Jack
Old Mar 28, 2002 | 01:27 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Who said you couldn't run leaded gas through fuel injectors. Someone better quick let the GN crowd and all the big power adder guys know
Old Mar 28, 2002 | 01:29 PM
monte-ss's Avatar
I was told the leaded gas would plug up the injectors, is this not true?
Old Mar 28, 2002 | 01:34 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Not true; however, it'll shorten the life of your O2 sensor, and I believe if you have a catalytic converter, leaded fuel will drastically shorten its life too. Injectors are fine.
Old Mar 28, 2002 | 04:51 PM
Ed Maher's Avatar
Car: 04 GTO
bryan623
Mar 22, 2021 06:43 PM
jklein337
Sep 19, 2018 06:23 PM
db057
Sep 4, 2015 07:57 AM
Jae992
Aug 27, 2015 09:07 AM
mdtoren
Aug 23, 2015 12:52 PM
