Vette to IROC
Old Mar 30, 2002 | 02:57 PM
88ROC1LE's Avatar
Vette to IROC
I have an opportunity to get some aluminum corvette heads off an 88 vette, i was wondering if it wold be to much of a hassle to put them on my 88 IROC. F.Y.I. He is dropping the motor in favor of a 400 small block
Old Mar 30, 2002 | 05:29 PM
RedIrocZ-28's Avatar
Car: Iroc-Z
Engine: 355 AFR'd HSR
Well, first you have to take off the TPI. That would take you an hour or 2 maybe depending on how fast you are working. Then you just unbolt the old heads and exhaust manifold. Considering the project I am doing right now on my 89 Iroc... I would give body parts for a task like this
Old Mar 30, 2002 | 06:09 PM
88ROC1LE's Avatar
So they should just bolt right up? What project are you undertaking?
Old Mar 30, 2002 | 11:02 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The vette heads have the old style manifold bolt angle, but you should be able to slot your bolt holes on the manifold.
Old Apr 2, 2002 | 02:46 AM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
First pocket port those #113 heads, 2.00/1.56" valves, RRs, toss the oil shedders, etc.; it's worth another 20-25hp to work those heads. If you like you can port match the intake runners to a larger base for later addition. The chambers are 58cc so you may need to open em up a little when porting.
You will need to get the external EGR tubes from the Vette and have the lower one welded into the passenger side exhaust manifold.
I think the TPI will bolt up since the heads are post '86.
Old Apr 2, 2002 | 06:48 AM
Jim85IROC's Avatar
Vette heads never went to the newer bolt angle. They all have the old style angle.
ex-x-fire
Jan 12, 2024 01:58 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
hokis
Wheels and Tires
Aug 26, 2015 04:21 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 11, 2015 03:17 PM
