Stoopid question, how to adjust the timing?
Old Apr 2, 2002 | 12:34 PM
Wes B.'s Avatar
My timing has a little retard in it. I've been wondering how do you adjust it? Thanx
Wes
Old Apr 2, 2002 | 12:52 PM
Drew's Avatar
Well kick the little retard out...
Look on the bottom side of your hood and see if you have a label or two... one of them should give the timing spec and explain everythign..
If not, find the EST, its a tan wire with a black stripe ont he main wiring harness. Usually its just above the heater box. Disconnect it. Connect a timing light to + - and around the #1 plug wire, fire up the car and point the timing light at the timing marker... I wanna say stock timing is 6* but to be honest I'm not sure. If its not right, loosen the hold down bolt (9/16) and turn the distributor slowly to get the correct setting.
Old Apr 2, 2002 | 12:55 PM
Wes B.'s Avatar
Thanx, I'll have to try it
Old Apr 2, 2002 | 12:59 PM
Drew's Avatar
BTW when you're finished reconnect the wire and disconnect the battery for 30 seconds to 5 minutes to reset the codes since having the EST disconnected will set a code in the ecm.
Old Apr 2, 2002 | 01:57 PM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
Another thing is to do this on a warm engine. I tried to adjust mine cold one day and it gave me some funky results.
Old Apr 2, 2002 | 03:15 PM
BOTTLEDZ28's Avatar
Transmission: A4
one stupid question here, when adjusting the timing, which way is advance on the timing marker and which is retard. from zero, which way up or down the balenser does it go
Old Apr 2, 2002 | 03:58 PM
Car: I
Engine: Taunt
You want to be on the passenger side of the timing marker, its the longer side, the biggest 'valley' (0`) seperates the two sides I describe. I belive the increments are 2` from valley to peak on the tab. Stock setting is 6`.
Old Apr 2, 2002 | 04:18 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I'm not sure when / if thirdgens chaged balancers, but on my 92 i sight the timing tab down from the driver's side top. The engine rotate clockwise when viewed from the front, so more advanced means the ignition fires sooner, so the mark will show more to the passenger side as you advance it further. As has already een stated, on a factory timing pointer, the first big gap is 0', the next high point is 4'. From there each valley / point is another 2'. The end of the balancer is 16' IIRC.
And factory spec for all TPI thirdgens is 6' btdc
Old Apr 3, 2002 | 12:34 AM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
Make sure all the wires on the distributor are on securely and all the way. Or else you might just get a peppy little shock when you reach over to rotate the distributor when that damn #3 plug wire is loose (i know from personal experience )
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
