Runner glue
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
well i turned the other runner over to our welder this morning.the runner that only needed the one side welded in?i was holding out because i was going to use that last peice of aluminum as an example when i went of fab shops.
"this is what i need..got any?"
well i caught a break today on the set of runners that i have been working on.i was talking to my buddy here at work while he was stamping information on a name plate for a boltlock switch.well i was looking at the name plate(made of alum.)and was thinking ya know that name plate is about the right width for what i need.i ask him to let me take a look at it.and told him that is almost perfect for what i need.i told him i would bring it right back i wanted our welder to take a look at it.he told me it's alittle thin but he could make it work.i was like"cool!!!"
i went back to see if we had any extra name plates and my buddy told me he had a couple hundred of them.so i was like"cool!!!!!!"
when i get a chance i'll post so pics of what i have done to the runners so far
Stay Tuned!!!!!!!!
hehehehe
Stay Tuned!!!!!!!!
hehehehe
Car: 91 Formula
Engine: 383 HSR
Transmission: 5th 700R4
Axle/Gears: 3.89
why not just buy a set of Arizona Speen and Marine Semi Siemese runners? like I did, it's the same concept and they work great I should know more on their flow capabilities when I get my new cam in.
Engine: 5.7 HSR
i'll anwser your question with a question
how much did you pay for those runners?
so far i have 0$ in this project just a little bit of time.
Your Arizona Speed semisiamesed runners are just that,
semisiamesed "RUNNERS". What Bandit has in his possesion
are actually plenum extensions. They are no longer runners
at all but will act as plenum area because the air mass will be
moving too slowly in them to have any positive effect on the
the cylinder filling properties of the intake as a whole.
In fact they will dampen filling properties at lower rpm's but
will enhance filling properties at higher rpm's
Zoom, Zoom.
Zoom, Zoom.
Hey Bandit, have you thought about what you are going to do
with the runner side of the base yet?
I was planning on cutting the headers of the runners to match
the new "B" shaped tube then do the same to the base with
a mild 1/2" siamese so the runners blend into the base nicely
and also cut the plenum to match.
If you want, I could send you the plenum and base that those
runners are from and you can port everything to match without
having your car down forever.
Engine: 5.7 HSR
Swapmaster that would be great!!!that i wont be with out a car while i port the rest of the intake.i really don't like driving my daily beater car
what i had planned on doing was cutiing out the runner deviders in the plenum to match the runners.with the base i was planning on cutting runner devider wall out about half way down.
i still need to do some research on what other people have gottin out of cutting the devider 1/4 of the way,half way or cut it out completly.
any thoughts?
any thoughts?
I will box them up and send them probably on Monday or
Tuesday. Personally I wouldn't go too deep on the base.
I think the runners are like 6-1/2" long in the base which will
run to 6,500 rpm if you open them up. Cutting 2" in should
raise the rpm range to about 7,500 rpm. So I would just try
to match them to the new runner openings as best you can
without creating a any sharp steps or a larger opening in the
base than the runners are. A small hole feeding into a larger
hole will create turbulance as the air pases any uneven mating
surfaces which will reduce air flow.
On the base side of the runners you could knife edge and
round off the leftover upper portion of the flange to eliminate
any sharp edges then siamese the base an inch or two at the
most. Just make sure you have a nice transition between the
two.
two.
Oh yea, don't worry about what other people have gotten out
of siamesing their bases. They were not working with fully
siamesed runners. You have a unique setup that will respond
differently than the rest. If you go 2" in, you will truly have
4-1/2" runners in the base without any tuning influence from
nonsiamesed runners adding subharmonic pulses to the mix
which I personally don't think is all that helpfull. But there is
really no way to tell, that's just my personal opinion.
Steaming shiznits Bat Man, that takes some snarley nads to
get that wacked. You must have to have your pants custom
taylored to have a sack pocket sewn in the crotch, don't ya?
I hope the flanges are still square when you are done. Why don't
you hold off welding the tops on until I send you the rest of the
intake. That way you can bolt it all together when he welds them
on so it don't warp out too bad.
I should get them boxed up tomorrow and send them Tuesday.
Engine: 5.7 HSR
thanks swapmaster i recieved the parts today
couple questions
on the base there are "studs"sticking out between the injector boss's what are those for?
there is a brass fitting right next to the dist. hole what's that for?
is this a Vette TPI?
couple questions
Engine: 5.7 HSR
well i wouldn't know anything about getting old
just turned 30 this past March but i still feel 21(with 50 year old knees)
just turned 30 this past March but i still feel 21(with 50 year old knees) Supreme Member
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Engine: 5.7 HSR
i really haven't had a whole lot of time to put towards the runners.been working alot and and working alot on getting my car to run right.take a look at these threads and see what you think
https://www.thirdgen.org/techbb2/sho...hreadid=125771
https://www.thirdgen.org/techbb2/sho...hreadid=125971
https://www.thirdgen.org/techbb2/sho...hreadid=125970
I was just wandering that myself the other night.
I haven't been on in a while. Started a new repair shop and have
been working 12 - 14 hour days. Too damn tired to do much but
eat and sleep for the last few months.
Anyone want to buy my 4dr Jag? I have a new toy comming. 1989
Jag 2dr convert V12 with an underhood fire. She gets a 383 with
one of John's LT1 intakes and an onboard laptop to keep her in
tune.
tune.
Engine: 5.7 HSR
spare time?what's that?
all i need to do is cut the other runner and trim and fit the peices of alum.
i just need to find the time to work on this
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Are you planning on cutting out the red parts of the picture below? If you don't you are going to have major air turbulence which will just be working against you.
Engine: 5.7 HSR
Engine: 5.7 HSR
well i been having some troubles with getting my car to run right after my 305 TBI to 350 TPI.but i hope to have these runners on here in the next couple weeks
stay tuned!
stay tuned!
Engine: 5.7 HSR
i just started to modify the base.i'm going to cut about an inche into the base runners.after that i may go even deeper and see what we get.
Engine: 5.7 HSR
and what?
there are people that were interested in how things were going so i was posting an update.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Yeah, I own the runners now.
3rd owner in 2 years.. THe evil runners.
I'll get some dyno time in with them vs my fully ported SLP's and report back.
-- Joe
-- Joe
Car: 92 Z28
Engine: Boosted LSX
Diggin this one up from the Grave.... Hopefully there is some new news on these runners. It might help out this guy.
https://www.thirdgen.org/techbb2/sho...72#post1942472
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
They flowed more than my slps.
I sold both setups.. All my tpi stuff is gone.
Another member owns them now. I only know him by his real name though. Maybe he'll chime in.
-- Joe
-- Joe
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
ya that wouold be really cool
unfortunatly my car got t-boned today so thats the end of that
going to have to part it out or buy another one
Car: 89 Formula
Engine: 355
That looks like a lot of work to cut and weld and fill and smooth them out. Why not just fill in the area between the runners with JB weld or what ever untill they are flat on both sides then hollow them out? Seems that would be much quicker but I have never done it.
I thought about that at the start but I don't think you could get the JB to stay stuck to the aluminum runner forever. Aluminum expands too much when it gets hot. Some of the new liquid solder compounds on the market may work though. Nice to see there is still intrest in this project. Who has them now? I am thinking about starting another set and would like to see some pictures of what they look like now.
Car: 1994 Trans Am
How old is this thread now, 3 years? I love grave digging.
So does anyone know what came of the actual results? Did anyone ever dyno those things? Bandit took over the project from Swampmaster, Anesthes bought them from Bandit and then later sold them to an unknown.
Who has these now and goddammit, dyno them or sell them to me so I can dyno them. SwampMaster, so you think siamesing the stock base will further help out flow?
Talk about grave digging, sheesh. I have a new theory I am thinking about. Siamese the base about 2 inches and only siamese the number 5 and 7 runners on the left hand side. With the base siamesed there is no real reason to do the runners except for number 5 and 7 because they draw air at the same time so they need more flow. I have a flow bench now and a way to weld aluminum so it's just a matter of finding time to get it done.
Engine: 5.7 HSR
-- Joe
-- Joe
Car: 1989 Trans Am GTA
Transmission: M28 T56
Zoom, Zoom.
Zoom, Zoom.
However, if you've got the skills, and tools nesessary to do the job, then it makes quite a bit more sense than spending $400 to $500 on a set of runners. I bought my AS&M SS runners for $300 and they are freaking brand new. I got a good deal.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
maybe you could contact this member and see what came of the bouncing runners
If you guys are really looking to "go fast" on the cheap, swing into the alternative efi board and check out some of the setups we've built.
-- Joe
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
I hogged out my base it cuts like butter with a burr and a high rpm wiz wheel. It's restricked like a champ where it mates with the head. I went a little crazy and hogged out my pleuinm and put a very small hole in the side of it this was my first time porting. i used 24 hour JB weld in the inner and outter area and put in nice layer around the hole. Does anyone think that it will or will not hold up to heat and all. After seeing the post those welding flux sticks might be better looking and safer. It's not that noticalbe with the jb weld and JB is really good stuff. I think it should be good. Please give me you're alls thoughs please.
Thank You
Thank You
Chas91Z28
Oct 22, 2015 10:12 AM
Royal_Z
Sep 30, 2015 08:45 PM
