No Power Under 2000rpm
Old Apr 3, 2002 | 03:59 PM
riz75's Avatar
my 91'z28 (305 tpi) started acting up a couple of weeks ago. when i would give the car gas it would hesitate for a split second (rpms would drop slightly) and then the car was fine. i added a fuel injector cleaner (chevron w/techron) yesterday and filled the tank.
this morning the car acted like it usually has (slight dips in the rpm), but when i left work today the car was acting crazy. the RPMs would drop down alot and cause the car to buck. it seems to only happen under 2000rpm. after 2000rpm the car seems fine. there are no funny noises from the engine and the idle is as steady as the day i bought the car (years ago).
please help me fix this problem
thak you in advance,
riz
Old Apr 3, 2002 | 07:38 PM
Shagwell's Avatar
Car: projects.......
My TPI always gives me crap when I put injector cleaner through it. It will idle rough, have dips in rpm and everything you were describing. - as for the hesitation, my original 350TPI didn't have that, but my current 305TPI does - no clue
Old Apr 3, 2002 | 08:10 PM
jerflash's Avatar
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
my 305 tpi idles bad also not sure why and does not do it all the time
but in the case of the hesitation i would put the accel coil that fits in the stock location
i go one and all hesitation was gone
Old Apr 12, 2002 | 08:46 PM
riz75's Avatar
turns out that my fuel injectors were clogged. 1 week after i put the cleaner in the car ran great.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
sailtexas186548
Aug 24, 2015 10:11 PM
