Car smoking
Old Apr 12, 2002 | 12:00 AM
86305's Avatar
Car smoking
Ok my car has had this problem for i while and i can't figure it out. It has a puff of white smoke when i first start it or if it sits and runs at an idle for a couple of minutes and then when i hit the gas. Everyone tells me it gas smoke. I want to fix it but i don't know whats causing it.
Any suggestions are appreciated i need to do something about it because it looks bad.
Old Apr 12, 2002 | 02:46 AM
RedIrocZ-28's Avatar
Car: Iroc-Z
Engine: 355 AFR'd HSR
Gas smoke! LMFAO!!! Its your valve seals most likely. Plan a minor engine rebuild in the future where you take the heads off and have them gone over and what not. Its your valve seals brutha!
Old Apr 12, 2002 | 08:07 AM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
if its white its means antifreeze, a blue/grey smoke would be oil, real black and sooty would be gas but thats running really rich and you would smell that instantly
Old Apr 12, 2002 | 09:44 AM
86305's Avatar
but it's not water and it can' be oill the damn thing don't lose oil.
Old Apr 12, 2002 | 11:20 AM
Pino91Formula's Avatar
if its white smoke it's your coolant , water, antifreeze. it really cant be anything els , you might have a crack in the head gasket near one of the water jackets.
Old Apr 12, 2002 | 02:11 PM
monte-ss's Avatar
it only takes a little ammount of water to make a lot of smoke, had a small ammount of water/antifreeze splash into the exhaust of a car I worked in when doing an R/R of the engine and it smoked for almost 10 minutes, other than the smell would have thought I was doing a helluva burn out!
Old Apr 12, 2002 | 02:20 PM
Bort62's Avatar
try Steam.
Water Dosent smoke
Old Apr 12, 2002 | 02:30 PM
monte-ss's Avatar
no water wont, antifreeze will
Old Apr 12, 2002 | 10:21 PM
86305's Avatar
I just put a different intake on it a while back can the intake gasket cause it. Or would that just let it get in the oil. And i just checked my water which i havn't done in about 3 months and it was a half a gallon low.
Old Apr 12, 2002 | 10:22 PM
86305's Avatar
But the smoke smells like gas a little.
bryan623
Mar 22, 2021 06:43 PM
fonzie85
Exterior Parts for Sale
Oct 10, 2015 10:55 PM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
squiggy2
Aug 9, 2015 09:30 PM
