i am almost finished swapping in my 355 need tpi help
Old Apr 5, 2002 | 07:49 PM
brettd's Avatar
This is an 86 tpi trans am
1. where does the neg. cable from the battery bolt to ?? I can remember for the life of me.
2. does anyone know what color and how many wires bolt to the starter
3. and for the alt.
brettt
Old Apr 5, 2002 | 07:57 PM
camaro-mayhem's Avatar
Car: Camaro
Engine: 355c.i.
Transmission: th350
uhhh i thought the negative cable bolted to somewhere on the block,like a bolt.I dont know if its different for TPI or not.
Old Apr 5, 2002 | 08:41 PM
BenDoe91z28's Avatar
my negative battery cable bolts to the closest header bolt to the batter.
Old Apr 6, 2002 | 10:04 PM
trigger GTA's Avatar
Car: 92 TA vert
you should have 3 wires on the big lug of the starter and one on the small lug labled S
the battery should go to the block. so long as its a good gnd. it will not mater where you put it. also be sure the engine is grounded to the frame also
ZMWojnar
Brakes
May 12, 2019 10:43 PM
InfinityShade
Aug 22, 2015 08:00 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
