question on holley stealth ram
Old Apr 6, 2002 | 12:29 PM
SuperChevy's Avatar
I have an 88 iroc and was wondering since the stealth ram doesn't bolt up to the stock heads which is no big deal because i was planning on replacing the heads anyway but my question is will the stealth ram bolt up to say l31 vortech heads?
Old Apr 6, 2002 | 01:12 PM
rhuarc30's Avatar
No
Old Apr 7, 2002 | 07:44 AM
e-man's Avatar
Car: 89 formula
Engine: 383
The stealth ram will bolt up you just have to drill(elongate) the four center bolt holes out a little higher.
Old Apr 7, 2002 | 09:01 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Not to Vortec heads, they are totally differant.
Old Apr 7, 2002 | 06:37 PM
90Form350's Avatar
yes totally different. otherwise there would be no demand for the special vortech intakes that everyone is making a fortune off of.
Old Apr 8, 2002 | 08:07 AM
e-man's Avatar
Car: 89 formula
Engine: 383
sorry missed the vortec head part was thinking about 87up heads
Old Apr 8, 2002 | 05:12 PM
SuperChevy's Avatar
so what kind of heads will bolt up directly to these for under 1,000 if there are any?
Old Apr 8, 2002 | 05:35 PM
90Form350's Avatar
any heads that are made for 86 or earlier "vehicles" (read:intakes) is acceptable for the stealth ram.
Old Apr 8, 2002 | 05:42 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
does anybody know if it will bolt up to the heads on a zz4 crate motor...
Old Apr 8, 2002 | 07:21 PM
SuperChevy's Avatar
anybody ever tried the phase 2 cast iron bow tie heads? and would they fit on the stealth ram? sorry for all the questions just trying to figure out what im gonna do to my roc cause summers comming up soon and as we all know its upgrade season
Old Apr 8, 2002 | 07:25 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Also the hood clearance issue. I just measured on a second gen. camaro and it looks like there is no way it would fit.
J
Old Apr 8, 2002 | 10:47 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
yes
9192camaro
16
Feb 3, 2019 12:21 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
L98GTA87
Aug 11, 2015 06:55 PM
