How do you tell if an Adj FPR is malfunctioning?
Old Apr 8, 2002 | 07:09 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I have my old Accell back in the car after the adj bolt snapped off in my Crane!
At idle I can get the pressure to hold at about 35psi. Any more and the needle starts to rapidly vibrate between 40 and 55 psi. So fast it's almost a blur.
Driving is okay up to 35-40mph. Above that I get +5deg timing retard, knock counts go up and my injector PW climbs. It's like the computer is trying to compensate for a lack of fuel.
Is this the symptom of a weak FPR or a dying fuel pump. I have had no other problem with the pump, car starts hot, cold, no matter.
Also does the hole the adj bolt goes down need to be air tight? When I drilled and retapped my crane the bolt is a little wobbly in the threads. Will this induce a vacuum leak in the unit?
WHo has the cheapest price on the holley AdjFPR?
Old Apr 8, 2002 | 10:20 PM
88ROC1LE's Avatar
I asked a mechanic and he said that the regulator needs to be airtight, something about maintaining the pressure. A quick fix for now would pry be some teflon tape on that bolt, but get it fixed soon! A molotov under the hood (a bad idea!!!)
Old Apr 9, 2002 | 04:48 AM
Rob P's Avatar
Engine: ZZ4TPI
Agreed! No leaky FPR's for me! Thanks for the reply.
Ed1LE
Sep 30, 2018 09:14 AM
92-Formula
Dec 12, 2015 10:34 PM
mike22115
Sep 28, 2015 04:49 AM
Lmancha96
Sep 25, 2015 08:11 PM
Strick1
Sep 4, 2015 07:11 AM
