Finished LT1 intake swap...take a look
Old Apr 8, 2002 | 10:35 PM
Steve10's Avatar
I finally finished the swap. It's amazing how uncluttered and clean my engine bay is now. I think I could change injectors in ~15 min. I just took it for a spin around the block with only one problem...I'm having a hell of a time getting the water neck to t-stat housing to stop leaking. I'm hooking it up to the scanner tomorrow and start the prom burning process. Stay tuned for performance results.
Old Apr 8, 2002 | 11:12 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Very nice. They look good red. Where did you get that fancy duct work (boot & pipe)? Is that an LT1 throttle body or TPI?
J
Old Apr 9, 2002 | 08:32 AM
Steve10's Avatar
I ordered two stainless elbows and found some stainless pipe at work, then had a guy in the shop weld it up for me. I ordered the red turbo hose connections from hose techniques.com to connect the MAF. I went ahead and had him cut me another piece of stainless to take the place of the MAF when I convert to MAP. The throttle body is a 58mm TPI Edlebrock that I was using on my LTR setup.
Old Apr 9, 2002 | 11:19 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Looks great! How did you paint the intake? I hope mine looks that good when I'm done. :hail:
Have you noticed any difference on the "butt dyno"?
I also have the ZZ4 motor, what were your times before you did the swap?
Old Apr 9, 2002 | 12:16 PM
Steve10's Avatar
First thing I did when I got the intake was a thorough cleaning, then a couple hours sanding and polishing out the top fins. I taped off the fins and the mating surfaces (TB, head), then painted with hi temp paint.
I've only driven it a 1/2 mile, just to make sure I had the throttle and TV cables working right, so I didn't run it hard. I guess I can tell a little loss in torque. Geez, this motor has always been unbelievable on the low end, so as long as I've gained it on top I don't care...maybe I can launch better now. My best g-tech run before the swap was 13.25 @108. I won't be doing any WOT runs until I get all the part throttle stuff tuned in. That could take 10 chip revisions. After a few scans and prom burns tonight I will definately have an opinion of the performance potential. If I find out I'm maxing the MAF to 255 gps at a low rpm, I'm going to go ahead and do the swap to MAP and 730 ECM right away, before I invest months into tuning this thing.
Old Apr 9, 2002 | 04:15 PM
1stgenracer's Avatar
How do u get a LT1 intake to fit on, what is that site that tells u how? also, did u see any different numbers in hp from the intake?thanks
Old Apr 9, 2002 | 04:23 PM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
I can help with the first part of that question. The site is http://www.lt1intake.com/
David
Old Apr 9, 2002 | 06:38 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Where did you get the fuel lines made?? I have checked with EVERYBODY here in Des Moines and they don't have the fittings!! I am currently finishing the LT1 intake swap and within a month I will have the new engine and trans installed as long as the money keeps flowing.
Old Apr 10, 2002 | 09:08 AM
Steve10's Avatar
I purchased the fuel lines from John Millican.
midge54
Dec 27, 2019 04:14 PM
Hawk312
Aug 22, 2017 08:55 PM
midge54
Jan 29, 2017 07:00 PM
midge54
Aug 29, 2015 09:51 PM
zayne0
Aug 24, 2015 07:22 PM
