Probably a Stupid Question but...
Old Apr 9, 2002 | 11:06 AM
jgifford's Avatar
Car: 1986 Z28
Engine: 355TPI 380hp
Transmission: Rebuilt 700r w/ Transgo Shift Kit
Is it possible to run a Vacuum Advanced Distributor on a TPI motor, and if so, where should the vacuum line come from?
Old Apr 9, 2002 | 11:35 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Possible, yes, you just need to send a signal into the distributor reference pulse for the ECM. However, what would be the point? You'd still need to get into the chip to tune the fuel. And if you're in the chip anyway, you might as well set your timing curve in there as well.
Old Apr 9, 2002 | 11:46 AM
jgifford's Avatar
Car: 1986 Z28
well, there wasn't exactly a purpose, it was a mistaken order from Summit, but I guess I'll send that one back. Is there any suggestions for a good aftermarket dist. My original is f***ed and I need a new one. I have heard that MSD has a good one, but that is won't fit the Edelbrock Hi-Flow intake, so any recomendations would be cool.
Cleotiz
Jan 6, 2018 08:56 PM
3.8TransAM
Sep 3, 2015 06:38 PM
masonta
Sep 1, 2015 06:40 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
