Wiring Question
Old Apr 9, 2002 | 10:15 PM
fcarman's Avatar
Wiring Question
I was wondering if I could get some diagram/pinouts for the attached image. It is the plug under the passenger side dash. The harnes is from an 87 Formula 350 TPI. My nearly 2 year project is coming to an end here, all help is mucho appreciated!
Old Apr 9, 2002 | 10:19 PM
TPI Monte SS's Avatar
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
Re: Wiring Question
Is that the dash side of the harness, or the engine side? I remember enough to know its the 15-pin IP harness, but don't remember which side. I have an '87 GM wiring diagram here, just let me know what you're looking for.
Old Apr 9, 2002 | 10:23 PM
fcarman's Avatar
The plug is wired into the engine and computer harness.
Old Apr 9, 2002 | 10:25 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Buy a $12 Chilton's manual. You'll need it later on anyway. It has the wiring diagrams.
That plug looks like the ones that supplies 12 v to injectors, fuel pump, etc.
J
Old Apr 9, 2002 | 10:32 PM
Car: 1988 Monte SS
What info do you need? What wire goes to where in the harness?
Here's a question, since I can't tell from the pic; is Pin A a Brown wire? It should be (if it's the harness I'm thinking of)
A= brown
B=red/black
C=brown/white
D=tan/white
E=white/black
etc... is this the plug?
Old Apr 9, 2002 | 10:37 PM
junkcltr's Avatar
Engine: 3xx ci tubo
I can see by the picture it is the only that takes the 2 seperate black plugs(the picture's mate). The one I talked about above.
J
Old Apr 9, 2002 | 10:44 PM
fcarman's Avatar
Monte thanks for helping me out here. I need to know where they go individually. I am wiring this plug into an LG4 car 86
A-Brown
B-Orange
C-Brown/White
D-Tan/White (largerwire)
E-White/Blk
F-Pink/Blk
G-Blk/Purple
H-Tan/Blk
J-Orange
K-Brown
L-(no wire)
M Blk/White
N-Orange/Blk
P-Purple
R-Purple
Old Apr 9, 2002 | 10:52 PM
Car: 1988 Monte SS
Allrighty then, here goes...pay attention class! This took me a bit of time to dig out, and was very valuable when we did my TPI swap two years ago.
A- goes to Pin C on ALDL
B- ALDL Pin G and fuel pump relay Pin D
C- SES light
D- to FP/ MAF relay
E- Pin B ALDL
F- ENG CNL fuse
G- from Gauge fuse; feeds air select valve, canister purge, AIR diverter, EGR
H- ALDL Pin F & TCC
K- to VSS
M- ground for lots 'o stuff
N- to gear selector switch
P- brake switch to TCC
R- CRK fuse to Cold Start Inj. and switch
Old Apr 9, 2002 | 10:58 PM
fcarman's Avatar
:hail: !Thanks a million! Hope she doesnt fry! :hail:
I will update on the fire good or Bad
Old Apr 9, 2002 | 11:02 PM
Car: 1988 Monte SS
Sounds good FCar, keep us posted!
Old Apr 11, 2002 | 10:02 PM
fcarman's Avatar
Well tha past couple days I have accomplised a few things. Changed gas tank and kick down cable.
Changed Y-Pipe and heater core tube today. Also, chopped off cat end and getting end replaced for the 3" TPI Y- pipe.
D@#! Star heads (runners and plenum)! (Had to curse them) Getting regular socket bolts so I can finish the runners, plenum, and valve covers, etc. up tomorrow and cat. Hopefully do some wire probing tomorrow without battery.
HOPING to attempt a start at least by saturday.
Old Apr 11, 2002 | 10:06 PM
Car: 1988 Monte SS
Hey, how was the sending unit in that TPI Tank you swapped in? I have a brand-new one in the box if you're interested.
When we did the TPI swap in my Monte, the dealer I ordered my parts from sent me that one, and I didn't know it wouldn't fit in my tank until 6-months later. Those rat bastards wouldn't take it back and stuck me with a $400 sending unit.
Any takers? $250 shipped to anywhere in the continental US!
Old Apr 11, 2002 | 10:12 PM
fcarman's Avatar
OUCH BABY VERY OUCH! $400!
Mine better be good. I was hoping to use my old sending unit because I knew it worked, but it was way different. I did use my old tank as the donar tank had rotten gas inside and a couple chunks. If mine doesnt work, I have NO intentions of changing it out anytime soon after that PITA tank swap. I did put in a new pump.
Old Apr 11, 2002 | 10:14 PM
fcarman's Avatar
There is only ONE place for that sending unit after they sold you the wrong one. UP THEIR A@#
Old Apr 11, 2002 | 10:19 PM
Car: 1988 Monte SS
Agreed! Too bad I mailordered it from a dealership in Ohio, and I live in Jersey.
Old Apr 13, 2002 | 09:02 PM
fcarman's Avatar
I gave 12volts to the injectors, cold start valve, fuel pump, and ecm. I have spark at plugs, but engine did not fire.
Was wondering where EXACTLY to run the wire from the fuel pump (tan/white)? I probed the large tan/white wire under the passenger side dash (common FP contact PIN-D) and it did not light during cranking or while ignition in run. Is this the correct location for the fuel pumpwire? If so, is there any reason why the test light is not lighting up during cranking on pin D?
Do the injectors ground at th ECM, if not then where do they ground? I dont think they are doing anything and I know they are getting 12 volts.
TOMORROW I PRAY IS THE DAY!
Old Apr 13, 2002 | 09:06 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Read my first post above. It will save you a lot of time.
J
Old Apr 13, 2002 | 11:49 PM
Car: 1988 Monte SS
The tan/white wire should run from Pin D, to the fuel pump/ MAF relay, connector 1 (pin A5) at the ECM itself, and to pin A at the fuel pump relay. The fuel pump signal wire coming out of the ECM should only light for two seconds in the "start" position, as it just primes the pump and then shuts off. After the car fires, the oil-pressure switch determines if the car will stay running or not.
The injectors do not ground at the ECM (according to my pic that breaks down the ECM connectors). Rather, the signal is fed through the ECM, and uses the ECM grounds that go to the back of the engine block.
Good luck! I'm no electrical engineer, so hopefully this does it for ya. I would really recommend buying the GM book for the car too. Its the Electrical Diagnosis book (Sevice Manual Supplement) for 1987 Camaros. It's really the most helpful thing I did when I swapped in the TPI, believe me!
Old Apr 14, 2002 | 12:47 AM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
what are you putting this in Fcar? as far as the fuel pick up, when I did my monte (orig carb) I just modified the pickup using the stock one took 2 good hose clamps and clamped the fuel pump to the original pick up tube, and put the filter on the bottom, I think I had to trim the bottom of the pick up right after it bends (just cut it off) used the old pick up as the new return line after I tightened the hose clamps I bent the remaining tail over the top of the tightener (if there is a technical term for the screw I dont know it) that way it wouldnt back out, its been operating like this for 4 years now and no problems ::knock:: on wood!
Old Apr 14, 2002 | 05:33 PM
fcarman's Avatar
ITS ALIVE!! Havnt got it on the road yet, but it idles and revs nicely to 4k (for now)! Cant wait to beat the **** out of it! :rockon:
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
