Stuck EGR valve causing bad idle and bad MPG???
Old Apr 10, 2002 | 10:13 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
I've been getting the EGR code lately and constant SES when driving sometimes. It also idles horribly (race cam) and then looses power when doing this. I'm thinking that the EGR diaphram is getting stuck sometimes causing this. If I floor it all the way thru 1st gear it usually clears up. Any thoughts?? Should i buy a new one or just take it off? How much do they costs? Thanks
* Oh yeah, its had a recent tuneup and I've checked almost everything else. Nothing else is bad that I know of... like the little stuff (wires, plugs, ignition module, cap/rotor, MSD box, AFPR, fuel pump, and o2 sensor)
Old Apr 10, 2002 | 11:03 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
if teh egr valve is hung open it is letting too much inert exhaust gas into the intake. causing the terrible idle quality you describe. it may also affect your MPG also. you can put a vaccum tester to the vaccum line goin to the EGR valve, draw vaccum thru the line and the diaphram should raise up, when you release the vaccum from the line the diapahram should go back down. it is common for EGR valves to get dirty and plugged and hang open. the only way to replace and or clean teh EGR and its passages is to remove the intake plenum. this is not a huge ordeal, but it does need to be taken into consideration.
Old Apr 10, 2002 | 04:20 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
re:
Thanks man. Thats what I was thinking. Its also hard to start lately... probably flooded with exhaust fumes. Well, guess I need to replace it or take it off Thanks again!
Old Apr 10, 2002 | 05:00 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
no problem. if i were you tho, i would keep it on there. it doesnt hurt you at wide open throttle anyway and it lowers combustion temps for lower emissions, and allows for more ignition timing and better mileage
Old Apr 11, 2002 | 01:16 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
re
Yeah, I need to just keep it. How much are they?
Old Apr 11, 2002 | 01:51 PM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
EGR valves are about $50 at the local Kragen. As stated earlier, it might just be stuck open from being dirty. If the diaphram is still intact you can just clean all the carbon crap out of it and it'll be fine.
Old Apr 11, 2002 | 04:23 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
re
Thanks. I think its getting stuck SOMETIMES. Not stuck all the time. Is it worn out or just needing cleaningl? Not sure what you're saying. Thanks!
1992rs/ss
16
Jan 28, 2016 09:58 PM
Out-Cast
Aug 17, 2015 10:57 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
