How to start a high powered TPI engine
Old Apr 12, 2002 | 03:32 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Hi...
Ever since I started to modify my engine its kinda hard to start when its warm. With my setup today I'll have to have 25-35% throttle to make it start otherwise its justs cranks and cranks...
Anybody elsa have this problem or know whats causing it?
Old Apr 12, 2002 | 03:42 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
I was thinking maybe u needed a sheild for the starter when I read this, but you need throttle??
Old Apr 12, 2002 | 07:50 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
have you replaced your fuel pump relay?the relay could be bad and your will still start.
Old Apr 12, 2002 | 11:26 AM
TPI Monte SS's Avatar
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
How far advanced is your timing? That's something else to consider....way advanced will cause hard starting problems.
Old Apr 12, 2002 | 12:01 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
The big question is: does it crank slowly, does it crank freely and not catch, or something else?
Old Apr 12, 2002 | 02:57 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
I would guess you have leaking injectors that flood the engine when it is warm and sits for a few minutes. By giving the car 25% throttle you are allowing the gas to clear out and the car starts. Does the car start fine when its cold? Does the car restart fine when its warm and you shut it off and then immediately restart it? If these questions can be answered with a yes, then I believe you have leaking injectors.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
The_Phoenix
Sep 3, 2015 10:56 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
