slow building RPM's while in gear?!?! WTF!!!
Old Apr 13, 2002 | 12:30 AM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
ok just got my car back together tonight, no vac leak's that I can find anywhere while the car was in the garage you could hit the throttle and it had a real fast response, ok great good to go take it to the carwash to give the car a bath, thing hardly move (good thing the car wash is a block away) if you held the throttle at a certain point with out pumping it it would slowly (verrrrrry at best) build up rpm's and now in park it hardly wont rev up at all my current modifications are RCR's old SLP runners and ported base/plenum, and some 1.6RR's remainder is in the sig.
thanks
Jack
Old Apr 13, 2002 | 03:50 PM
monte-ss's Avatar
anyone?
Old Apr 13, 2002 | 05:55 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I am sure you already checked but, I will ask still because it does happen. is there any thing in the air duct? rage or any thing before or after the air filter?
Old Apr 13, 2002 | 07:01 PM
monte-ss's Avatar
I dont think so but Ill double check, its pretty much open all the way it comes off the cowl induction hood I have, custom jobbie with a bug rectangle knn filter Im begining to think its bad gas but Ill check anything anyone can give me ideas for.
thanks
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
forstral
Aug 19, 2015 03:20 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
hokis
Aug 9, 2015 03:57 PM
