drilling out vb feed holes
Old Apr 23, 2002 | 02:03 PM
Idagon's Avatar
do i drill out the 3-4 feed hole to .187
and the tv hole to .062
the 3-2 high speed to .093
2nd hole to .110
thanks,
Dan
Old Apr 23, 2002 | 02:25 PM
Pro Built Automatics's Avatar
With the stock torque converter drill the 2nd gear feed to .086, .096 MAX! Drill 3rd feed to .110. If you get a chance call me, and I will be able to help you out on this a little better than I can here. 800 7763288 M-S 10-6 PST.
Old Apr 23, 2002 | 10:51 PM
Idagon's Avatar
tv sleeve
i plugged the 2 holes in the sleeve (the 2 in the u shaped cutout,
180 degrees apart from each other)
the tranny still kicks dowm into 3rd gear
after drilling the vb and plugging the accumulator feed hole
the 3-4 shift is much better
any idea why it still kicks down into 3rd?
Old Apr 24, 2002 | 02:54 AM
Is it kicking down as easy as it used to? If not how much throttle does it take to get it to kick down?
Old Apr 24, 2002 | 08:17 AM
Idagon's Avatar
it seems about 3/4 throttle at 50 mph
Old Apr 24, 2002 | 08:23 AM
Idagon's Avatar
isnt it supposed to stay in 4th no matter how much throttle you give it
or is that above certain speeds
how about the 3-4 full throttle shift, will it be able to
or do i have to modify something else to get it to do this?
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
FormulasOnly
Oct 2, 2015 05:52 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
drumstixer
Sep 29, 2015 03:02 PM
dusterbd
Sep 29, 2015 08:40 AM
