Will 3.73 T/A gears work in my car?
I have an '82 Camaro SC with a 350SBC, TH200 and 2.73's.
I have the option to buy a TH350 and limited slip rearend gearing from a 1977 TransAM for about $200 Canadian. Will the gearing fit in my car? Does any one know what ratio gearing the factory equiped the T/A's with? Also did the T/A's tranny's have the right Tailshaft length for a direct bolt on? Thanks guys
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
3:73's
No they won't fit. Yours are 7.5 the '77 is 8.2 or 8.5 ring gear size.
The 350 trans should be the same length as the th200. Although I don't think the 350 would have a tq. arm mount but you can get an after market one.(tq. arm brkt.)
Don>>>
Don>>>
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
you can find 3.42 gears in the overdrive S-10 trucks and 3.42 or 3.73 in alot of F body cars with T5 and 700r4, i have a nice 1984 F body 3.73 axle complete i would sell for cheap if you had way to get it.. they are common ratio axles to find, all i ever run into are 3.73 around here, i finally found a 2.73 one, that was hard to find.. i also have a 78-87 G body 2.28 axle for sale chesp, dont need it, its tight and clean, anyeone know where i can advertise either axle ? i trade for chevy truck parts 67-72, so....i would trrade the whole 84 SE for as truck body of any year, 71-87 running or not, trucks and 80-older cars are hard as hell to find in central IL these days.. i nedd to quit all this and move west or south, AR and AZ have TONS of OLD stuff everywhere, i about died when i went to AR couple weeks back, damn.,, no rust even,, thats sick,...
hectre13
Dec 11, 2023 08:14 AM
dhonda200
Aug 11, 2015 11:50 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
