I replaced my throwout bearing, but the problem persists. Please help.
305tbi t-5 When I put the shifter in gear, any gear, but keep the clutch disengaged(foot all the way down on the clutch), I have what sounds like a grinding or it really sounds like the throwout bearing running on the pressure plate. It stops if I put it in neutral. I replaced the bearing. It was my first time, but it went smoothly. Did I do something wrong. Any suggestions greatly appreciated.
Car: 82 Z-28
Engine: 383 TPI
Your throwout bearing, if bad, will make noise anytime the clutch pedel is depressed; assuming the eng is running.
You said the noise goes away when in neutral, was that with your foot off the clutch?
If you have a noise that appears with tranny in gear, goes away when shifted to neutral, and the clutch is depressed the whole time, could be your clutch is not fully disengaging.
Car: 82 Z-28
Engine: 383 TPI
I've always had an automatic in my Z, so I'm not real familiar with your set-up, but I'd be looking at the hyds first.
Have you bleed the system yet?
theshackle
Sep 17, 2020 08:26 AM
red90IROCls1
Aug 25, 2015 06:56 AM
db057
Aug 11, 2015 10:11 PM
