Spin Resistant Rearend Posi???
Old Apr 30, 2002 | 08:20 PM
Don_89Iroc's Avatar
the tag on my rearend housing said "Spin Resistant Diff" and somthing about "use approved gear lube" anyways my freinds rearend he got is posi for sure and his tag said "limited-slip Diff" i was just wondering is my rear a posi, if so its not working right cause i only spin one tire Thanks - Don
Old Apr 30, 2002 | 10:22 PM
capn_crash84's Avatar
sounds like you got one of two things
1. Someone thought it would be funny to put the wrong tag on your diff.
2. Your posi isn't working right, possibly worn out.
I'm not an expert on it, but i have a posi rear axle off of an 86 trans am, and it says Spin resistant on the tag. My guess is GM either changed the way they stated it, or its a different model posi.
-crash
Old Apr 30, 2002 | 10:33 PM
88IROCZ350's Avatar
well... i'm not an expert here but heres something to think about. My tag says Slip resistant Diff. and its a 9 bolt, your car is a 89 iroc which is pry a 9 bolt, what year is your friends car? is it a 10 bolt? that would make a difference because the 9 bolts are australian rear ends. hth
Old May 2, 2002 | 06:49 AM
Don_89Iroc's Avatar
yes my friend got his rear end off a 86 Iroc and it has 3.27's i belive and it said "limited slip Diff" on it and it is a 10 bolt, a also have heard a 9 bolt is a stronger rearend, is this true?
Old May 2, 2002 | 07:18 AM
Eightyninef's Avatar
my 9 bolt tag says spin resistant. It's the aussi english translation to limited slip.
I spent last week with 2 aussi's. an "elevator" is called a "lift".
"right away" is said "straight away"
man is mate.
there is a language barrier even though they speak "english"
Old May 2, 2002 | 03:16 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Yep. A tight 9 bolt is much stronger than a 10 bolt. More info is at www.9bolt.com
Miles
Old Feb 1, 2018 | 10:49 PM
gtaformula's Avatar
Re: Spin Resistant Rearend Posi???
I have an 87' GTA,and it says the same."Slip Resistant",tag on right rear of Dif. Was wondering the same. It is an 9 Bolt.
Old Feb 2, 2018 | 12:15 AM
Camaro86IrocZ's Avatar
Car: '86 Iroc Z & '91 RS
Engine: 305 TPI & 305 Qjet - Future LC9
Count the bolts on the rear cover, either 9 or 10 there...
Old Feb 2, 2018 | 06:55 AM
big gear head's Avatar
Bringing back a 15 year old thread.
Old Feb 2, 2018 | 07:05 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Early morning reading, big gear head!
Old Feb 2, 2018 | 07:20 AM
I've seen some old ones brought back, but I don't recall seeing one 15 years old before.
Anyway, gtaformula, welcome. Some people on here are nicer than me, and some are not.
Old Feb 2, 2018 | 07:44 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Now that you mention it, I think you're right on the age of the thread being brought back to life. It's all good. Lemme go back and find a good one from 2000!
Again, welcome gtaformula!
Old Feb 2, 2018 | 11:12 PM
gtaformula's Avatar
Thanks for the welcome. New Rad put in last week, Brakes are in.Looking forward to a test drive in the next few days. Guess I will find out if it is a 1 tire fire or not. Will get some pics up here soon.
Old Feb 3, 2018 | 09:11 AM
As far as I know all of the 9 bolt rear ends had the Borg Warner limited slip differential. I have seen one picture of a 9 bolt standard differential, but never seen one in person. The Borg Warner unit will wear out and then it will start spinning one tire, but it can be rebuilt 1 time. If yours only spins one tire then it will need to be rebuilt or replaced. There is a better differential available now for the 9 bolt. It's the Eaton Truetrac and a few people on this sight have used them and they love them.
Old Feb 3, 2018 | 02:53 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
16 years old!
Old Feb 3, 2018 | 03:41 PM
Hey, at least they searched!!! (and found, no less) Could be worse.
Old Feb 3, 2018 | 09:49 PM
Originally Posted by 84 1LE
16 years old!
Ha, I counted wrong didn't I? I'm still stuck in 2017.
Old Feb 3, 2018 | 10:12 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
You didnt miss by much.
Old Feb 4, 2018 | 12:47 AM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Exactly. It's a little frustrating to see a post on a subject that's been answered a hundred times. Good use of a great site. Keep digging gtaformula and you will find a ton of information on the 9 bolt.
Old Feb 4, 2018 | 01:32 PM
There is a good thread on here about how to recondition the Borg Warner differential. If you look at the stickys you will find several links to 9 bolt threads that have a lot of useful information.
sheachopper
Jul 31, 2019 11:27 AM
KO1
16
Oct 15, 2015 05:00 PM
